Ford 6.7 Charging issues.......look here - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2014, 10:41 AM   #1
frdboy
frdboy's Avatar
Default Ford 6.7 Charging issues.......look here
Thought I would post this here to maybe help someone out down the road
Had my first 6.7 in the shop today.....2011, 80K miles
Came in with the battery light on although it was still charging......had a code P0625 (Generator Field Terminal Circuit Low)
I found what I think will be a common problem unless they fixed it in the later years, Ford ran the alternator control wires in a plastic holder with the a heavy power and ground cable.......heavy cable lays on top of little wires, rubs through the insulation and wire corrodes.
I decided instead of fixing the one bad wire and having another issue with this truck later I would replace all three wires and run them separate from the heavy ones. I used a 3 wire with heavy insulation.
Old May 8th, 2014, 10:43 AM   #2
xj4life
xj4life's Avatar
love the attention to detail. dont just fix the superficial issue, find the root cause and fix that.
Page generated in 0.20986 seconds with 29 queries
