Tire size questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2014, 06:13 PM   #1
captiancobble
lost in translation
captiancobble's Avatar
Default Tire size questions
What is the tallest/widest tire size i can run stock? Its a '90 and i dont want to lift it or trim fenders just looking to make the little motor a bit happier at highway speeds (4000 rpm @ 70mph) 5 speed manual
captiancobble is offline   Reply With Quote
Old May 7th, 2014, 04:00 AM   #2
choppergar
choppergar's Avatar
I run 235x75x15 on 8" rims works fine.
choppergar is offline   Reply With Quote
Old May 7th, 2014, 08:46 PM   #3
scottie
Eye candy
scottie's Avatar
235 75 15's will rub on the pinch weld and the front bumper tube.
I really want to say that you can only go to 215/75/15 with no rubbing (on stock wheels), but you may be able to get 225/70 or 75's to fit.
and 235's typically mess up the gearing so 5th is useless, but since you have the lower 5th gear it may be ok.
Page generated in 0.17354 seconds with 32 queries
