D60 Kingpin Caliper Bracket/s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2014, 09:35 PM   #1
Leanz
Full taste of tender
Leanz's Avatar
Red face D60 Kingpin Caliper Bracket/s
I need a drivers side caliper bracket Dana 60 king pin (for a late 70's f250 if that mattters). While researching online, I see ones with 6 bolt holes and ones with 5, not sure of the difference but I need the one with 5 bolts like below.
Leanz is offline   Reply With Quote
Old May 6th, 2014, 08:27 AM   #2
bbaXJ
Yooper In Training
bbaXJ's Avatar
5 bolt is what Ford used, 6 bolt was on Chevy and Dodge kingpin 60s
Old May 6th, 2014, 10:27 AM   #3
Leanz
Leanz's Avatar
Oh thanks, that helps a lot! :)
Old May 6th, 2014, 11:04 AM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Let me look, I think there's still a set in the garage.
Old May 6th, 2014, 11:07 AM   #5
Leanz
Leanz's Avatar
I'll wait here
Old May 6th, 2014, 12:09 PM   #6
lt1yj
FWIW I prefer the '86 - '93? style better. The late 70's vintage seem to spread apart and the caliper gets loose in the bracket which can lead to the little spring plate popping out. I've seen if happen on the trail and I've seen several axles that have had cobbled brackets that look like they're trying to fix the issue come through my shop.
You'll need to change to the later style calipers at the same time so it's not a direct swap.
lt1yj is offline   Reply With Quote
Old May 6th, 2014, 12:36 PM   #7
Leanz
Leanz's Avatar
I am aware of the spreading issue, then chucking your calipers out onto the trail lol, unfortunatly I don't want to switch calipers and all of that at this time. I guess I will just wait until it happens to me. I also have an extended key kit for my calipers, appears to be working well, but my jeep isn't moving yet
Old May 6th, 2014, 12:37 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
Napa sells a kit that spaces the caliper up, so even if the channel gap spreads slightly, it will not allow the caliper to fall out.
The spacer from napa is $9.32
Old May 6th, 2014, 12:40 PM   #9
Leanz
Leanz's Avatar
I have said spacer.... I called it my extended key
Old May 6th, 2014, 12:42 PM   #10
clarkstoncracker
lol
that is like calling a 3" lift "bigger tires"
Old May 6th, 2014, 01:16 PM   #11
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old May 6th, 2014, 02:51 PM   #12
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
whoa whoa whoa, you still have a jeep?
Old May 6th, 2014, 02:58 PM   #13
Tom
Because racecar
Tom's Avatar
I might has 1. I think it is the D.side, I'll check my bucket O' Dana 60 stuff tonight after the kids go to bed.
Old May 6th, 2014, 11:59 PM   #14
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I checked and I have a set left. You have to take both.
Old May 7th, 2014, 01:09 AM   #15
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I had my drivers side wedge pop out and it got stuck between caliper and rim and punctured rim. I took bracket to local machine shop and they built it up with weld and machined it down. The caliper fits very nice now.
Old May 7th, 2014, 12:57 PM   #16
clarkstoncracker
lol
she needs the driver side, so that is perfect!
how much y0 want for dem? If tranny can't come up with the one, I'll swing out and grab the pair
Old May 7th, 2014, 01:14 PM   #17
I am pretty sure that the same year F250 HP Dana 44HD's use the same brackets. I have 1 or 2 of them, that I'm not using. I'll try to head out to the barn and look tonight. I drive right past Z. Electric every morning...
Old May 7th, 2014, 01:18 PM   #18
clarkstoncracker
lol
Waiting on Tom's reply. If it's a drivers side, I'll snag them. Johnny messaged me, and I'll take his if Tom doesn't pan out.
thanks guys. Hopefully Leanz' jeep will be complete by the end of June
Old May 9th, 2014, 07:08 PM   #19
little_yj_95
little_yj_95's Avatar
I'm am running a dana 44 bracket on my d60 but I had to have the center milled out bigger for the axle to go through.
little_yj_95 is offline   Reply With Quote
Old May 9th, 2014, 08:44 PM   #20
Leanz
Leanz's Avatar
So happy with the responses! I figured I would be stuck buying some junk off of ebay and paying $20 shipping.
Page generated in 0.61732 seconds with 83 queries
