Would you use this knuckle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2014, 11:34 PM   #1
xj bmx
SLAYER!!
xj bmx's Avatar
Send a message via AIM to xj bmx Send a message via Skype™ to xj bmx
Default Would you use this knuckle?
A while back picked up a Ford d44 to go into my Cherokee. I had the driver's side knuckle sand blasted and powder coated. When I picked it up I noticed this.
Inside the upper ball joint hole. Its about .125 wide and about equally deep. I hope to have both crane knuckles down the road but i'm not sure if I should trust this on for now.
xj bmx is offline   Reply With Quote
Old May 2nd, 2014, 12:22 AM   #2
Wramblerguy
Wramblerguy's Avatar
Itl be fine
Looks original
If it held the truck for that long it will hold under a cherokee
3rd generation jeeper
Old May 2nd, 2014, 01:09 AM   #3
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I would run it
Old May 2nd, 2014, 03:00 AM   #4
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Run it
Woodyjiw is offline   Reply With Quote
Old May 2nd, 2014, 04:07 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Run it
H.o.r.e
Old May 2nd, 2014, 04:13 AM   #6
curbdog17
Mini Van
curbdog17's Avatar
I would use that knuckle.
Old May 2nd, 2014, 06:44 AM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
If anything fill it with some epoxy, but yeah it's fine.
Old May 2nd, 2014, 09:10 PM   #8
xj bmx
SLAYER!!
xj bmx's Avatar
Wow wasn't expecting that haha, but ok will do.
And yeah I if I did I was going to atleast fill it with something to hopefully keep it from getting worse.
Old May 3rd, 2014, 06:42 AM   #9
I don't think you need to fill it but if you do, use the good JB Weld.
Old May 3rd, 2014, 09:13 AM   #10
Bones
Bones's Avatar
no epoxy or JB weld will make bit of difference with cast.
Just run it.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 3rd, 2014, 09:18 AM   #11
The only thing it will do will to keep the edges from fraying into the hole........ which is not an issue.
Old May 3rd, 2014, 01:31 PM   #12
xj bmx
SLAYER!!
xj bmx's Avatar
Just run it.
Well obviously not to keep it from breaking, just to keep the possibility of water staying in there and making it rot more.
This axle seems like was a literal boat anchor for a while. To the point I plan on putting new inner Cs it also haha.
No joke.
Old May 3rd, 2014, 06:39 PM   #13
Wramblerguy
No joke.
Ahhh
Just throw some gussets on em
Page generated in 0.22173 seconds with 62 queries
