Factory Rear Blocks for a F-350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 29th, 2014, 12:16 PM   #1
Coyote Red
Coyote Red's Avatar
Default Factory Rear Blocks for a F-350
It lools like both of my center pins are broken on the rear axle blocks. I believe anything from 1987-1996 will interchange. Looking for parts around the Jackson, Ann Arbor, and Flint areas if possible.
Coyote Red is offline   Reply With Quote
Old April 29th, 2014, 12:42 PM   #2
frdboy
frdboy's Avatar
I think I still have a set, I can check late tonight.
Old April 29th, 2014, 12:45 PM   #3
Lousypirate
Whoop Whoop
Lousypirate's Avatar
will the blocks off the eliminator fit Cody?
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old April 29th, 2014, 01:36 PM   #4
Coyote Red
Coyote Red's Avatar
Jake, I will have to get some numbers and compare. I am pretty sure they are 4" vertical blocks.
Old April 29th, 2014, 01:37 PM   #5
Lousypirate
Whoop Whoop
mine are 3" blocks, with cast in center pin. 2.5" wide IIRC.
I'll cut ya a sweet deal if you think they'll work for you. It involves (plus shipping costs if you need it faster)
Mary Jane (46 CJ2a)
Old April 29th, 2014, 01:45 PM   #6
Coyote Red
Coyote Red's Avatar
Frdboy would you ship them?
Old April 29th, 2014, 02:46 PM   #7
frdboy
frdboy's Avatar
Yeah, no problem. Let me see what they are and I will get back to ya.
Old May 1st, 2014, 10:10 PM   #8
frdboy
frdboy's Avatar
These were off my 95...but they are only 2"
Old May 8th, 2014, 03:00 PM   #9
Coyote Red
Coyote Red's Avatar
Those are what I need, except I think mine are taller. Did those come off a 4x4?
Old May 8th, 2014, 03:02 PM   #10
frdboy
frdboy's Avatar
Yeah, but it was a 3/4 ton, the 1 tons might have had bigger ones.
Old May 8th, 2014, 03:06 PM   #11
Coyote Red
Coyote Red's Avatar
I think they did. I have always heard that a SAS swap with a 60 requires a 4" lift. Thanks for checking for me.
Old May 8th, 2014, 04:39 PM   #12
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Heres what I have in my for sale thread. Dunno if you need or can use the slight caster change. I can ship these priority. There is no center pin. You use 1 long bolt through springs and these blocks.
3" lift blocks. Cast iron. They were on a Bronco I had. Have about 10 degrees of caster in them. 2 1/2" wide, 5" long. They are 3.25" in the back and 3" in front. $25
Daddy Dan is offline   Reply With Quote
Old May 9th, 2014, 09:03 PM   #13
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
I have a wet of 3" from a 2005 F350. I'm not sure if those would work for you because of the year difference.
Page generated in 0.28611 seconds with 62 queries
