Frekin' spartan locker??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 26th, 2014, 09:48 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default Frekin' spartan locker???
So, had a good working spartan locker in my dana 60F, with 35spline shafts for a year ish. Hasn't been wheeled alot, next to no street time. It worked flawlessly, UNTIL I broke both front axle shafts at the same time. Now it will hang up and not disengage once and a blue moon. Typically whenever I'm trying to turn. It binds so bad, from the front being like a spool, and the shafts not being phased, that I can barely turn with my full hydro.
Pulled the cover, pulled it apart. ..looked good. Re installed it.. (didn't do anything to change it, but thought it'd b worth a shot) and I still have the same issue.
The clearance between gears is .155" Spartan book says between .145-.170" so that should be good.
I know I know u get what u pay for....but thought I'd see if anyone else has had this issue?
If I can't figure it out in the next few night's it'll be a welded front diff..:)
Thanks for your help, ahead of time, GL4X4.
sended frum dis stoopid fone
Old April 26th, 2014, 10:08 PM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
If you scrap it I will buy it. I stripped one side of mine, I flipped it side for side and it works in forward now but still slips in reverse.
Old April 26th, 2014, 11:57 PM   #3
Andy456123
Guest
What size tire? While they work for some I've also seen them succomb to the limits of the design. And there's a limit to what a stanard open carrier can do.
Andy456123 is offline   Reply With Quote
Old April 27th, 2014, 06:25 AM   #4
big86inthestixx
39.5 iroks.
Old May 14th, 2014, 04:30 AM   #5
big86inthestixx
Tore it out and welded the spiders, simply because I needed it to work for the weekend. Now that it is out, I see that the pins were cracked and chipped. So I ordered a new pin kit, and am selling this.
I am 98% sure that the pins were all the problem had been all along. must have missed that the other few times I removed them.
here is a link to my for sale ad if anyone has any interest. currently open to offers. :)
thanks
Dana 60 spartan Locker (35SPL) $200.00 - Great Lakes 4x4. The largest offroad forum in the Midwest
Page generated in 0.23395 seconds with 39 queries
