(Trans help)!!!2005 jeep grand Cherokee 5.7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2014, 08:37 AM   #1
Jesse128
128
Jesse128's Avatar
Default (Trans help)!!!2005 jeep grand Cherokee 5.7
I was driving on the eway today and it shifted down to 3rd gear and stayed in 3rd. I have been doing some reading already and people have said it's called safe mode? When it does that. This is the first time it has happened. I also read that the filters crack and let's it such air. Also read there are some speed sensors? or something like that on the trans that could go bad. The jeep has 97000 miles and I guess what I'm asking is if this is a common problem with jeep or if anyone knows what's wrong. When I get home I'm gonna plug it in and see what my scanner tells me
Jesse128 is offline   Reply With Quote
Old April 23rd, 2014, 08:48 AM   #2
Tom
Because racecar
Tom's Avatar
Have it scanned for codes and report back with the code number and description.
When the trans gets put into limp mode it means the computer senses a problem, throws a code and puts into a safe mode.
People can list 15 things that "could" be your problem, but the easiest and fastest way is to have it scanned. It will give you a starting point and prevent you from just throwing parts at it guessing what is wrong with it.
Old April 23rd, 2014, 12:23 PM   #3
Jesse128
128
Jesse128's Avatar
Thank you. I have a OTC genisys I'm gonna plug it in when I get out of work. Thanks again I definitely don't want to just throw parts at it
Old April 23rd, 2014, 07:49 PM   #4
Jesse128
128
Jesse128's Avatar
P0988 4C Pressure Switch Rationality
Old April 23rd, 2014, 07:57 PM   #5
Jesse128
128
Jesse128's Avatar
The first code was from the trans computer and this one is from the engine P0700 transmission control system ( malfunction indicator lamp request)
Old April 23rd, 2014, 08:04 PM   #6
Jesse128
128
Jesse128's Avatar
I'm looking at modulation pressure on my scanner and it says no data. KEO and KER
Page generated in 0.25471 seconds with 41 queries
