Yj wiring with v8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2014, 09:53 PM   #1
masterbeatty
masterbeatty's Avatar
Default Yj wiring with v8
Ok so I bought a manual and I've been staring at this thing, harness is a 95. I'm putting a carbed big block ford in it. For some reason I'm running the struggle bus. I need to supply a trigger wire to my starter relay. I need power for lights, wipers, I think that's it. I feel like I'm over thinking all this. Out of my harness to the fuse box on the pass fender what wire do I need to pull for a starter relay. Now lights and everything body should be run off what I have like it normally would if it had a 4.0 I'd assume. So I shouldn't have to touch that. My distributer should just need a hot lead correct?
Old April 21st, 2014, 10:05 PM   #2
firehawk
Live Action!
firehawk's Avatar
Use the one from the original starter circuit.
Might need a test light to confirm the right one.
Old April 21st, 2014, 10:11 PM   #3
masterbeatty
I'm worried about issues with the auto shut down relay is there any reason to be concerned about that?
Old April 22nd, 2014, 04:31 PM   #4
masterbeatty
Anyone have anymore info
Old April 22nd, 2014, 04:37 PM   #5
Toyfish
Toyfish's Avatar
Push button starter! Lol
Sent from my DROID X2 using Tapatalk 2
Old April 22nd, 2014, 04:43 PM   #6
masterbeatty
Negative. I mean if I have to in order to get to the blessing I will but I don't want to
Sent from my XT1080 using Tapatalk
Old April 27th, 2014, 05:02 PM   #7
Wehan
Wehan's Avatar
this is the firewall bulkhead connection. When looking at it in the Jeep from the front, the right side is for all your headlights, horn, wiper squirter etc, the left side is what you want to start probing. I'm about to start a similar swap except mine is a TBI Chevy 350. Hope this helps.
Wehan is offline   Reply With Quote
Old April 27th, 2014, 05:32 PM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Have a suit case of money and I'll come do it
Old April 30th, 2014, 10:09 AM   #9
masterbeatty
I'll get you a suitcase full of money when will you be here
Page generated in 0.20398 seconds with 50 queries
