power trax failure - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2014, 08:45 PM   #1
Torg38
TorgFab
Torg38's Avatar
Default power trax failure
Question, I had a wj that came into the shop with a rear axle failure. The cross shaft ripped itself out of the carrier. It was an open carrier with a power trax in it. The power trax turns out to be for a c clip style d35 not the non c clip style its installed it. Does anyone know the difference in the power trax? And besides crosspin failure what normally causes this. (Weak carrier? Crosspin slop?)
Torg38 is offline   Reply With Quote
Old April 21st, 2014, 12:36 AM   #2
Wramblerguy
Wramblerguy's Avatar
A wj should have a c-clip d35
The non c-clip axles were pre 89 I believe
3rd generation jeeper
Old April 27th, 2014, 03:57 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Wrong. The WJ has a bolt-in Dana 35 axle.
The only difference is the cut-out for the the c-clip, provided it's for a 1993.5 and later differential.
The Dana 35 carrier is notorious for breaking and spitting out spider gears. It was probably caused by the installation of the powertrax but being for a c-clip axle probably has nothing to do with it.
Old April 30th, 2014, 07:28 PM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
@8ptbuck
Page generated in 0.23126 seconds with 35 queries
