YJ: Rear Main Seal removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2014, 05:30 AM   #1
CB10101
CB10101's Avatar
Default Rear Main Seal removal
My rear main seal is baked into the groove. I got the lower half out but struggling with the top.
I have loosened the bearing caps going forward hoping to relieve some pressure and have been carefully tapping the seal with a punch. So far, it has only moved a mm and I can't grab it with pliers yet.
Anyone have any other suggestions?
CB10101 is offline   Reply With Quote
Old April 20th, 2014, 05:45 AM   #2
Immortal
NO RELIGION WAT!
Immortal's Avatar
Persistence. Make sure you're hitting the wire rod.
Hit it in both directions working it back and fourth. I've also used a rubber tipped blow nozzle to help loosen up the seal. Be sure to wear safety goggles!!!
Old April 20th, 2014, 07:01 AM   #3
CB10101
CB10101's Avatar
Thanks. Would it hurt to shoot a little penetrating oil around the seal also?
Old April 20th, 2014, 06:42 PM   #4
CB10101
CB10101's Avatar
Finally got it! Used a little liquid wrench and tapping from both sides then it came right out.
Drinking a victory beer before the new seal goes in.
Old September 1st, 2014, 10:04 AM   #5
CB10101
CB10101's Avatar
Got the rms changed then developed another bad leak immediately. Found out it was the oil pan gasket at the rear didn't seat properly. Bought a new seal and same thing. So I ended up just cutting off the radiused portion and using permatex. No leaks!!!
Now a new issue though...in first and second gear, as soon as I let out the clutch, I hear a weird grinding/scraping sound. Is it possible that I got some oil and gunk on my clutch during the process? It does go away in 3rd and 4th.
Page generated in 0.19404 seconds with 38 queries
