WJ: Why remove front DS ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2014, 09:25 AM   #1
ThisOldJeep
Default Why remove front DS ?
I've seen a couple ads for wj's on craigslist that mention the front ds has been removed because of a problem with the front axle.
My question is why would the jeep be driveable w/o front ds but not driveable with the front d/s?
ThisOldJeep is offline   Reply With Quote
Old April 18th, 2014, 04:20 PM   #2
oz97tj
Wasn't this attached?
oz97tj's Avatar
Pinion bearing loose
worn out driveshaft
messed up t case
Removing the driveshaft removes lots of places where large amounts of play could be. It also removes the link from the tcase so a problem there isnt noticed.
Im not familiar enough with that particular model to say but there is likely a common problem someplace if this is popping up multiple places.
********GLFWDA.org********
Old April 18th, 2014, 05:06 PM   #3
Tizken
Ours is out due to a messed up transfer case. Still sounds horrible though. Many of them have a full time 4wd t-bone that is expensive to fix or replace.
Tizken is offline   Reply With Quote
Old April 18th, 2014, 06:15 PM   #4
michigan maniac
michigan maniac's Avatar
We got one in the shop right now with the spider gears blown to pieces
Page generated in 0.18625 seconds with 35 queries
