Yj with t18 clutch linkage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2014, 10:03 AM   #1
masterbeatty
masterbeatty's Avatar
Default Yj with t18 clutch linkage
What's my best option for a clutch linkage? Its running the ford bell housing and a big block
Old April 17th, 2014, 10:25 AM   #2
Toyfish
Toyfish's Avatar
U will prolly have to fab something up
Sent from my DROID X2 using Tapatalk 2
Toyfish is online now   Reply With Quote
Old April 17th, 2014, 10:42 AM   #3
masterbeatty
I figured I would but will a cable be sufficient or will I need actual linkage? I suppose that's my dilema
Old April 17th, 2014, 10:45 AM   #4
Toyfish
Toyfish's Avatar
Hmmm thats a good question
Old April 17th, 2014, 11:10 AM   #5
masterbeatty
It would be swell if the ax parts would swap over
Old April 17th, 2014, 12:20 PM   #6
Do you have the release arm in place?
On my CJ5, I used the hydraulic clutch from a 1980 4 cylinder CJ, which has an external slave that worked with the original (mechanically operated) release arm.
Although once I switched to inside the frame headers, I had to switch back to a mechanical bellcrank, for fitment issues.
Old April 17th, 2014, 03:18 PM   #7
masterbeatty
Yea the arm is in the trans still.
Old April 17th, 2014, 04:24 PM   #8
I have all the CJ mechanical bellcrank parts, you can have them for free if you come get them. One side bolts to the tub, one side bolts to bellhousing.
Old April 17th, 2014, 08:30 PM   #9
Sandals
Fucking Zen as Shit
Sandals's Avatar
I have my T-18 driven hydraulically.
Stock bellcrank parts, stock slave cylinder and CNC master cylinder.
Sandals is online now   Reply With Quote
Old August 27th, 2014, 06:59 PM   #10
masterbeatty
Any idea how this could be converted to hydraulic like the factory ax-15 is?
Old August 28th, 2014, 07:20 PM   #11
Sandals
Fucking Zen as Shit
Sandals's Avatar
Look on summit, get external slave cylinder, master cylinder, some fluid and some line.
Install hydraulic master cylinder,
fab and mount slave so it engages the clutch arm
run hyd line betweenthe two,
bleed system,
party.
Old August 28th, 2014, 07:35 PM   #12
masterbeatty
Possible to use my Yj master to push a universal slave?
Old August 29th, 2014, 11:58 AM   #13
Sandals
Fucking Zen as Shit
Sandals's Avatar
Yeah, if you can fab it in there sure, i think i went with a CJ stock slave.
Depending on what year YJ some had non bleedable slaves and used hard plastic tubing to connect to the master, not ideal.
Old August 29th, 2014, 01:17 PM   #14
I did the CJ slave on my old T15. I just picked up a T18 to go into my CJ7, I just plan on the complete CJ setup. I would match the master to the tub. When I started reading up last week, seemed people used universals or the CJ slaves.
Old August 29th, 2014, 04:30 PM   #15
Wramblerguy
Wramblerguy's Avatar
Yj master doesn't have any way of attaching anything other then the plastic line if I remember right
Mounting holes are closer together but no biggy
A cj 4cyl clutch master uses regular brake line fitting then get an aftermarket slave they mounts to the outside of the bell like stated above
3rd generation jeeper
Old August 29th, 2014, 06:06 PM   #16
There are ways to get rid of the plastic line. Here is one example.
http://comancheclub.com/topic/28758-...xed-with-pics/
Old August 29th, 2014, 10:03 PM   #17
Wramblerguy
That works too I guess lol
I think the Cj master and standard brake line would be cheaper tho
Old August 30th, 2014, 04:14 PM   #18
Yep, just need to modify the firewall a bit, as the mounting studs that go through to the pedal are different spacing.
Old August 31st, 2014, 08:52 AM   #19
Wramblerguy
Old February 2nd, 2015, 10:23 PM   #20
masterbeatty
Hmm well reviving this project finaly I'm going to have to look
Into a few of these ideas
Page generated in 0.42438 seconds with 83 queries
