Jeep 2.5 no spark or fuel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2014, 09:08 PM   #1
Wramblerguy
Wramblerguy's Avatar
Default Jeep 2.5 no spark or fuel
Ok so I drove my jeep in the barn and swapped motors now I don't have spark or fuel
New motor is all painted up so I'm wondering if I'm missing a ground somewhere
Motor is grounded to the frame to the battery
Can jump the fuel relay and the pump comes in
The pump doesn't do it's 2 second cycle when the key is turned on
I'm thinking cps but that doesn't explain the pump not even cycling with the key, does it?
Need help!
3rd generation jeeper
Old April 15th, 2014, 09:14 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Check the asd relay. It powers the pump relay and all the powers for coil, injectors, o2, cam and crank along with others. Should be a green/orange wire with battery voltage koeo
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 15th, 2014, 09:22 PM   #3
Wramblerguy
We checked and switched all the relays around so I'm prety sure it's not a relay
Old April 15th, 2014, 09:24 PM   #4
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
Battery is dead.
Just kidding. I have nothng useful to add. Carry on.
concreteguy82 is offline   Reply With Quote
Old April 15th, 2014, 09:42 PM   #5
Toyfish
Toyfish's Avatar
Double check all your grounds
Sent from my DROID X2 using Tapatalk 2
Old April 16th, 2014, 12:23 AM   #6
Wramblerguy
That's what I did but I'm not sure I got them all
Where does the computer ground thru?
Old April 16th, 2014, 01:06 AM   #7
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Sounds like the auto shutdown relay is not powering up. I would guess bad ground or computer. I have a computer if needed to try/buy.
Old April 16th, 2014, 04:12 AM   #8
Wramblerguy
I don't think it the computer since I drove the jeep in the barn 2 weeks ago
I think it's a ground I just don't know what ground I'm missing
All the brackets and the motor itself was painted so it's highly likely it's not grounding
I know the big ground by the alternator is working because I cleaned that one and it goes to the frame to the battery
Page generated in 0.22732 seconds with 47 queries
