NP 231 Electric switch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2014, 10:50 AM   #1
Cerveja
Default NP 231 Electric switch
Has anyone retrofitted their NP231 with the electric switch which mounts to the back (or maybe it's the front, been a while) of the T-Case? On some models it's a vacuum switch, on others it's electric, on mine it's covered over and not present. I would like to add the electric switch to my T-Case but not sure how it works or when it is "ON" or "OFF". It looks like a simple push button switch which keys off the shift fork shaft. What I would like to do is install an electric version and relay it to power the switches for my lockers. My hope is that it's a simple ON/OFF (Normally Open/Close) switch and not some fancy variable resistance switch designed to feed back into the ECM. I would like to add it as a safety such that I can only engage the lockers in four low so if I forget to turn them off when leaving the parking lot or my interior switch gets tripped accidentally while normal driving that I don't find out the hard way and the T-Case switch keeps them de-powered when i shouldn't be using them.
Any advice would be great. Thanks.
Cerveja is offline   Reply With Quote
Old April 22nd, 2014, 07:38 PM   #2
skife
skife's Avatar
sounds like you're over complicating this.
put a switch on the tcase lever, use that switch as a ground to engage you're e lockers.
pull jeep out of 4x4, you lose power to your elockers. (assuming e lockers require constant power to keep them locked in)
Old April 22nd, 2014, 08:03 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Switch on the transfer case makes perfect sense
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Page generated in 0.18154 seconds with 32 queries
