1999 D30 issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2014, 08:48 AM   #1
dochereford
Thumbs up 1999 D30 issues
I just purchased a 1999 XJ. The front ujoint on the axle are pretty bad. What should I consider replacing while I have it apart.? e.g. seals, bearings....
dochereford is offline   Reply With Quote
Old April 11th, 2014, 09:13 AM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
how many miles?
The Kernel (46 CJ2a)
Wow, i would lick those...
Old April 11th, 2014, 09:38 AM   #3
jbsjunk
Little Member
jbsjunk's Avatar
It would be a good idea to change it while you have it in your hands. You can confirm it when it's out.
Old April 11th, 2014, 10:55 AM   #4
dochereford
144k
jbsjunk, change what?
Old April 11th, 2014, 10:57 AM   #5
Lousypirate
Whoop Whoop
everything.
I had to do wheel bearings/ball joints, so I went ahead and did everything else.
One of my shafts has a binding joint though now, and I f'ed up one of the tone rings for the ABS, so the relay is pulled
Old April 11th, 2014, 01:36 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Originally Posted by dochereford View Post
144k
You were asking about axle joints. I said what I would do.
Old April 11th, 2014, 03:24 PM   #7
Dylan
Dylan's Avatar
I think he was referring to the unit bearings. with 144k (and assuming stock tires) the bearings should still be good. Unless the jeep was abused, there is no reason to change them. That front end is so easy to work on, I would just change the joints and be done. The only other thing that needs to come apart are the brakes. So if you want to do a brake job, pads/rotors, than there is no reason to do anything else. You can leave the wheel bearing attached when you change joints. Do yourself a favor and sand the inside of the wheel bearing surface on the hub and use lots of anti-seze when putting it back together. That way if anything else needs to be fixed later, you can pull it apart easier.
Just give it a visual while you are in there. Ball joints, rod ends, and wheel bearing. At 144k miles daily drive, those should be ok. I wouldn't change it all just because the wheel joints are bad. Chances are you will have to do the wheel joints again before anything else is needed.
Old April 11th, 2014, 09:28 PM   #8
dochereford
its not leaking any oil, but the seals on the end of the diff tube are messed up. The seals right before the ujoints...
Old April 11th, 2014, 09:44 PM   #9
jbsjunk
Little Member
jbsjunk's Avatar
Those aren't seals. Just hard plastic on the axle to keep most of the crap out of the tubes. The seals are internal next to the diff inside.
Old April 11th, 2014, 09:49 PM   #10
RioGrande
RioGrande
RioGrande's Avatar
If you are pulling the axles, I would change the seals, and even install these http://www.4wd.com/Jeep-Drivetrain-J...FW5eOgodYFgA7Q
And make sure the sealing surfaces of the axle are smooth/sanded.
RioGrande is offline   Reply With Quote
Tags
d30, ujoints
Page generated in 0.27702 seconds with 53 queries
