xj rolls over but wont start help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2014, 10:42 AM   #1
kchittle12
kchittle12's Avatar
Default xj rolls over but wont start help
my 98 xj started up just fine and when i went to leave it just shut off on me.. now when i turn the key it rolls over but wont actually start.. i think its the crankshaft sensor... what does everyone think
kchittle12 is offline   Reply With Quote
Old April 8th, 2014, 10:45 AM   #2
Hi Im Adam
I think you're spot on.
Hi Im Adam is offline   Reply With Quote
Old April 8th, 2014, 10:46 AM   #3
GREASYHANDS
GREASYHANDS's Avatar
Guessing costs extra
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 8th, 2014, 10:47 AM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
I would suspect neutral safety switch.
While in park row through the gears once or twice.
Put it back in park and firmly keep forward pressure on the shifter and see if it starts.
Old April 8th, 2014, 10:48 AM   #5
Lousypirate
Whoop Whoop
Lousypirate's Avatar
http://www.cherokeeforum.com/f67/98-...oblems-121516/
The Kernel (46 CJ2a)
Wow, i would lick those...
Old April 8th, 2014, 01:07 PM   #6
kchittle12
kchittle12's Avatar
i tried running thru the gears so i know its not my neutral safety switch..
just didnt know what else it could be
Old April 8th, 2014, 01:48 PM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
If you have spark then cam positioning sensor.
Swap it out with a used one to test it.
Old April 8th, 2014, 01:56 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old April 8th, 2014, 02:49 PM   #9
Immortal
NO RELIGION WAT!
Immortal's Avatar
I don't care. Not my money if the guy spends it on new parts
I'm 99% positive it is the cps or the fuel pump
Old April 8th, 2014, 03:16 PM   #10
Dylan
Dylan's Avatar
why not test it before you just buy parts.
1st off, bad NSS = no crank. Not no start
check for spark at a plug. If you get spark, then spray started fluid down the intake. It should run. If no spark, it could be crank or cam. More likely crank sensor.
If you have a scanner, read the live RPM as you crank. If nothing than bad crank sensor.
If it runs on spray and dies, check fuel pump relay and fuel pump by jumping wires. All that should be free or next to free to test.
Old April 8th, 2014, 03:29 PM   #11
Immortal
NO RELIGION WAT!
Immortal's Avatar
yes
oops....forgot
I still think cam, but how can you tell if it's either or. I got a used cps from a yard and put that on my 98 and it fixed it.
Old April 9th, 2014, 08:59 AM   #12
kchittle12
kchittle12's Avatar
Just changed the crank sensor and still nothing and it is getting fuel
I'll have to check and see if I have spark from the plugs or not
Old April 9th, 2014, 09:13 AM   #13
Immortal
NO RELIGION WAT!
Immortal's Avatar
Shit I meant cam sensor (cps) in the distributor.
Old April 9th, 2014, 11:54 AM   #14
firehawk
Live Action!
firehawk's Avatar
It wants its belly rubbed when it rolls over
Old April 9th, 2014, 01:21 PM   #15
kchittle12
kchittle12's Avatar
it doesnt have a cam sensor
going to see if i get spark tomorrow morning
Old April 9th, 2014, 02:29 PM   #16
GREASYHANDS
It has a cam sensor
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 9th, 2014, 02:39 PM   #17
Immortal
NO RELIGION WAT!
Immortal's Avatar
It has a cam sensor
He said it doesn't.
Old April 10th, 2014, 09:26 AM   #18
kchittle12
kchittle12's Avatar
Lost it has no spark and when I hook it up to the coil it also has no spark
Could it be a bad coil
Old April 10th, 2014, 09:27 AM   #19
dirtydude
dirtydude's Avatar
Hit the starter with a hammer
dirtydude is offline   Reply With Quote
Old April 10th, 2014, 09:27 AM   #20
dirtydude
dirtydude's Avatar
It'll start
Page generated in 0.31498 seconds with 83 queries
