Charging Trouble - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2006, 07:57 PM   #1
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
Default Charging Trouble
I have a 1976 Ford 390 in a F150 4x4. I put on a new ALT. & Voltage regulator and it still isn't charging. What an I missing?
Mijeeper CJ 7 is offline   Reply With Quote
Old November 14th, 2006, 08:00 PM   #2
chris1044
chris1044's Avatar
Whats the voltage drop of the positive cable from the back of the alt to the battery? Possible corrosion there. Also, are all your connections good? What about the battery?
Secondly, where did you get the alt from? I've seen brand "new" alternators not charge right after installation....it's possible that it's simply defective....
Old November 14th, 2006, 08:06 PM   #3
Mijeeper CJ 7
New battery, connections appear to be good and tight, cleaned the battery connection on back of alt. I'm going to take the new alt. in for a test hopefully it is just a bad alt.
Old November 14th, 2006, 09:41 PM   #4
chris1044
chris1044's Avatar
if it was a reman it's highly possible....i'd say atleast 1 in 5 I install end up as junk (per carquest usually)
Old November 15th, 2006, 05:15 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
did you polarize the regulator? if not non if it will work.
Yetti
Old November 15th, 2006, 06:06 PM   #6
Mijeeper CJ 7
I can't really say what I did but it's charging now. All I know is there was sparks and now it's charging.
Page generated in 0.15052 seconds with 41 queries
