2000 ram van 3500 HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2014, 08:31 PM   #1
eagle-eye
Default 2000 ram van 3500 HELP
The van has a 5.9 engine and auto trans. The problem is that the brake and abs lights are lit, relays click like crazy and the fuel pump runs continuously. All of this is while the key is on engine off. The engine will barely start let alone run. I pulled the trans harness off( the 3 wire plug on the driver side) and there is corrosion/dirt in it. I am thinking a bad ecm as this is what these vans are known for.
What do yall think?
If it is a bad ecm, could the trans plug have cause it?
If this doesnt sound right, what do i test?
What are the relays in the interior fuse box as the plate doesnt tell me.
Thanks in advance!
eagle-eye is offline   Reply With Quote
Old April 7th, 2014, 11:05 PM   #2
blackbronco92
300 Inline 6
blackbronco92's Avatar
I would definitely point towards a toasted ECM with those symptoms.
Any corroded connections *could* short out the ECM, but I wouldn't suspect the trans. harness. It's possible, but most likely you had corrosion issues in the ECM itself which is most common. However, I'd clean up any connections I can before hooking up the next ECM. Good Luck!
blackbronco92 is offline   Reply With Quote
Page generated in 0.11841 seconds with 29 queries
