dropping the t case ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2014, 12:09 PM   #1
derbydude
derbydude
derbydude's Avatar
Default dropping the t case ???
I am putting a 4.5" short arm lift on my 99 xj, running 32" tires and using off road only . Is it a must that I drop my t case ? If so how much is recommended ? Thank you.
derbydude is offline   Reply With Quote
Old March 28th, 2014, 01:32 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
The norm is approx 3/4". I have a new drop kit I didn't use because I went with a SYE kit. Every XJ seems to be different on these. Some go without with no problems, others have vibration issues unless this is used. If it's not in the kit, you can go without and see how it goes. Depends on where the threshold is. There are double caron driveshafts for a slip yoke style too.
Old April 8th, 2014, 10:38 AM   #3
Immortal
NO RELIGION WAT!
Immortal's Avatar
With a double cardon I just shim'd my rear axle.
Boom! No vibrations!
Your welcome.
Give me all your casino cash!
Old April 14th, 2014, 06:56 PM   #4
ericschmidt
ericschmidt's Avatar
I never had any vibe issues, but when I went from my bb 2" to over 5", I just bought longer bolts and stacks of washers for my "drop kit". You can add or remove washers to tweek it to where you need it. I ended up with a hair under an inch on he drop. I had no vibes with the 99 xj, only stupid bump steer because of other issues...
ericschmidt is offline   Reply With Quote
Page generated in 0.22131 seconds with 35 queries
