93 explorer starting issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2006, 12:39 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default 93 explorer starting issues
i have replaced the battery cables and the battery is brand new. the starter is new also. every once in awhile (when it feels like it) the car wont start and the key just makes one click. i go under the hood and touch the celinoid and it starts right up. some days it works some days it doesnt. what could it be?
nate4d is offline   Reply With Quote
Old November 14th, 2006, 01:16 PM   #2
Icebreaker88
Icebreaker88's Avatar
Have you replaced the starter Solinoid?
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old November 14th, 2006, 01:19 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Re-tighten everything and double-check those connections. It sounds like a connection problem.
Old November 14th, 2006, 01:54 PM   #4
Bones
Bones's Avatar
sounds liek a ground, or lack of
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 14th, 2006, 04:19 PM   #5
Blackjackbender
if u have to hit the solenoid its most likely sticking.
replace the solenoid and the problems should go away. my solenoid sticks on my mustang alot but it sticks when im cranking it and keeps the starter cranking.
Old November 14th, 2006, 04:58 PM   #6
nate4d
Gnarley Davidson
nate4d's Avatar
yea i got ya. rust could cause a lack of ground for the electrical and i need to clean them up im sure. this thing has 290,000 miles on it. runs strong when it starts. thanx to all that replied.
Old November 14th, 2006, 05:25 PM   #7
chris1044
chris1044's Avatar
eh, you sure that you're touching the solenoid - I could have sworn that it was located on the starter itself
Old November 14th, 2006, 08:25 PM   #8
nate4d
Gnarley Davidson
nate4d's Avatar
i was told it was the solinoid but im no good with fords. when i touch whatever it is located under the hood behind the battery on the inner fender wall area (pass side) with a wrench (connecting the two bolts momentarily) it starts
Old November 14th, 2006, 10:14 PM   #9
nate4d
Gnarley Davidson
nate4d's Avatar
everytime i clean the battery and cables it works like a charm but i dont know how it gets so gross so quick. i want to try that felt trick but dont have any haha. its my girlfriends car and all i hear is her yelling about how its not working and for me to fix it so id like a soild fix.
Old November 14th, 2006, 10:54 PM   #10
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Coat the connectors in some di-electric (sp?) grease. Just make sure you don't accidentially ground anything with it by getting it everywhere.
Old November 15th, 2006, 08:35 AM   #11
nate4d
Gnarley Davidson
nate4d's Avatar
ill try it out. thanx capt.
Old November 16th, 2006, 10:39 AM   #12
Blackjackbender
replace the solenoid. DEE DEE DEE
Old December 13th, 2006, 08:27 AM   #13
cculter
climb-on
cculter's Avatar
Don't replace the solenoid, the problem is coroded battery terminals. This happens about every 6 months with mine, clean them up real good, works like a charm.
cculter is offline   Reply With Quote
Page generated in 0.33372 seconds with 62 queries
