4:11 or 4:56 in LJ with 33's? UPDATED 8.17.2014 - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2014, 01:40 PM   #41
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Originally Posted by joe_jeep View Post
4.56 is a waste. Take them back get 4.88 or 5.13.
the od ratio is .69.
I had 4.56's with 32's in my XJ, it's overdrive was .7:1, so pretty close. I spun about 2450 rpm going 70, which is barely higher than it did with stock tires/gears. I was able to pull down about 18/19 mpg on the highway with my stroker.
Blue XJ is offline   Reply With Quote
Old June 4th, 2014, 01:59 PM   #42
2fst4you
2fst4you's Avatar
4.56 isn't a bad choice but if you aren't driving on the freeway imo you can never go too low
Old June 4th, 2014, 08:44 PM   #43
Bullhed78
Bullhed78's Avatar
Wow, this thread kinda rose from the dead. I did buy 4:56's and think I will be extremely happy with them. BigBChevy is a busy man. I will report back when the gears are in.
Bullhed78 is offline   Reply With Quote
Old June 4th, 2014, 10:48 PM   #44
joe_jeep
welfare wheeler
joe_jeep's Avatar
Aw4s are .75 od.
Old August 8th, 2014, 09:18 PM   #45
Bullhed78
Bullhed78's Avatar
So the 4:56's have been in for just about a month now. The drivability of my LJ is way better now. At 70 MPH it cruises at about 2350 RPM's. As far as mileage goes, it's actually the same as I was getting with the 3:73's. The jeep was bought in Florida and driven home to Michigan and it averaged 15.5 MPG. After the 4:56's were installed I drove it up to the Keweenaw Peninsula in the U.P. and back and it averaged 15.5 MPG. Around town milage was and still is 13 - 14 MPG. All and all I think the gear swap was a win. I got way better drivability and didn't loose any gas mileage.
Old August 17th, 2014, 04:40 PM   #46
Bullhed78
Bullhed78's Avatar
Another update:
I took the LJ to Silver Lake sand dunes this weekend. The 4:56's seem to be a perfect choice for my wants/needs. I aired down to 10 psi and did almost everything I wanted to do. The only thing I couldn't climb was the far right (west?) side of test hill where it was very steep and I blame that more on the automatic than the gear ratio. I checked milage on the 160 mile trip home and got 17.1 mpg. I was running around 68 - 70 mph on the highway for about 125 miles and 55 mph on the backroads for the remaining 35 miles. All in all I am extremely happy with the drive ability and offroad ability of the 4:56 ratio and the 4 speed auto.
Old August 18th, 2014, 01:21 AM   #47
1 ton tj on 40's
1 ton tj on 40's's Avatar
what did you get worked out on the locker that went bang?
Old August 18th, 2014, 07:52 AM   #48
Bullhed78
Bullhed78's Avatar
It was a demo locker so I let them know that it didn't work. LoL. They are going to do more R&D to fix the problem. They sent me all new bearings and I'm just running an open front end for now.
Old August 18th, 2014, 09:03 AM   #49
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Originally Posted by Bullhed78 View Post
Another update:
How far off is your speedometer or did you change the gear in the t-case? if so how did you know what gear to buy?
CHEVYRCKS is offline   Reply With Quote
Old August 18th, 2014, 10:14 AM   #50
Bullhed78
Bullhed78's Avatar
I changed the gear. If memory serves me correctly I had to put a 39 tooth in it. I told Jared at Americas Most Wanted what tires and gear ratio I am running and he told me what tooth count I needed. I'm sure there are calculators online. I think Quadratec has a chart in their catalog also.
Old August 18th, 2014, 10:22 AM   #51
1 ton tj on 40's
that's cool he sent you new shit
Old August 18th, 2014, 12:26 PM   #52
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Cool, I will have to check into it for mine. Thanks
Old August 18th, 2014, 12:31 PM   #53
bigbchevy
missmrgreenagain
bigbchevy's Avatar
that's a great guy to deal with
H.o.r.e
Old November 9th, 2014, 09:01 AM   #54
Blue XJ
The Green Machine
Blue XJ's Avatar
Aw4s are .75 od.
Not the Renix era ones, the 21 spline version is .70:1. 1991 and up are .75
Page generated in 0.28627 seconds with 65 queries
