Suggestions for mounting electric fans to the radiator? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2014, 01:03 PM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default Suggestions for mounting electric fans to the radiator?
I'm putting electric fans on my Ram. Looking for suggestions to how to mount them on the engine compartment side of the radiator that are not hack, yet simple. Looking at it, I could run 2 pieces of flat steel across the radiator to each of the upper and lower points where the shroud bolts to the tanks. I know I've seen some sort of system that mounts through the radiator, similar to a zip tie. Anyone ever use that setup? How did you like it? Did it mount the fan tight to the radiator, or was there a little gap? Thanks!
Ready4Wheelin is offline   Reply With Quote
Old March 24th, 2014, 01:13 PM   #2
firehawk
Live Action!
firehawk's Avatar
I would not use the zip tie type. If it has a shroud built into the fan then verticle bars can work but if not then a shroud that covers the whole radiator is best, mounted to the radiator.
Old March 24th, 2014, 01:44 PM   #3
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I agree. The shroud should provide some spacing of the fan from the radiator so you don't eventually rub through the tubes and fins.
Old March 24th, 2014, 02:34 PM   #4
The standard thru the fin plastic ties have a foam spacer to go between the 2 pieces. I know no one likes them but I have never had anything rub through............. except when a dumbass (me ) lets a hose clamp rub against a tube.
Old March 24th, 2014, 05:18 PM   #5
Ready4Wheelin
Thanks for the info guys. I'm probably going to go with the steel brackets bolted to the shroud mounts on the tanks. That will give me about 1/2 to 3/4 inch gap between the fans and radiator. Wasn't sure about the plastic tie method, just know that I've seen it and wondered if anyone ran it.
Old March 24th, 2014, 05:44 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I've always used the zip tie strips with the insulator. They need to be tight though, or they will fatigue and break.
Old March 25th, 2014, 04:49 AM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Screw those zip tie thingies! After doing a sweet wheelie with my jeep the front end came down and the fan ejected off from the radiator and landed on the moving belts. Now I have to buy a new fan.
Old March 25th, 2014, 05:39 AM   #8
or stop doing wheelies.........
Old March 25th, 2014, 07:05 AM   #9
chadcooper55
Why on earth would you want to stop doing wheelies?
Old March 25th, 2014, 07:06 AM   #10
firehawk
Live Action!
firehawk's Avatar
x6
Page generated in 0.25380 seconds with 53 queries
