***SOLD***Fixed Lower Control Arms --3"6" lift TJ XJ MJ LJ.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2006, 10:14 AM   #1
xjmichigan
xjmichigan's Avatar
Arrow ***SOLD***Fixed Lower Control Arms --3"6" lift TJ XJ MJ LJ..
used/ still is great condition
they have been repainted black a while ago
$50
SOLD
xjmichigan is offline
Old November 14th, 2006, 10:24 AM   #2
Icebreaker88
Icebreaker88's Avatar
PM sent
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline
Old November 14th, 2006, 12:04 PM   #3
mrclean
Silver Lake
mrclean's Avatar
front or rear? I would imagine front
I'll take them if Mike doesn't
mrclean is offline
Old November 14th, 2006, 12:09 PM   #4
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
I'll take them if they don't take them.
FrankNBrew is offline
Old November 14th, 2006, 12:12 PM   #5
xjmichigan
xjmichigan's Avatar
mike wanted to know if these would fit his ZJ for the rears
Old November 14th, 2006, 12:38 PM   #6
Icebreaker88
My rear lower arms measure 16.25" center-center of the bolts. I think I need arms about 1" longer for the 4" lift that is on there. Those arms measure about the same as mine staight line but are 17" if you follow the bend. Not 100% sure if these are the arms I need. Any input would be appriciated. And no Trav you cant just say they wont work so you can get them :miff:
Old November 14th, 2006, 01:01 PM   #7
Icebreaker88
I called a few places and those arms wont work for the rear of the ZJ. I need arms about 17-17.5" for the rear measuring straight line. ZJ arms are about 1" diffrent from the front to rear.
Old November 14th, 2006, 01:27 PM   #8
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
No, they won't work for the rear. :tonka: (he didn't say I couldn't say it)
It all depends on your driveline angles. FYI, I have a set of RE superflex arms on the back of my TJ. They measure 16" exactly, and they work great. That's with 1.75" coil spacers and Rubicon springs.
They will bolt up, but you really need to measure driveline angles. Unbolt the rear control arms, and adjust the pinion so the pinion sits 1-2 degrees below the output shaft angle. Then measure how much longer your lower arms need to be. I have a feeling 1" longer is way too much. I'm guessing somewhere between 16.00-16.5" is what you need.
Another nice thing about the RE super flex arms in the rear is the flex joint on one end, and the stock bushing on the other. There's alot less pinion wrap. Not so important when they are on the front. In fact, the stock busings on both ends makes for less harshness transferred to the vehicle.
Why can't I stop typing??? :chiefwoohaw:
Old November 18th, 2006, 07:22 PM   #9
xjmichigan
xjmichigan's Avatar
Icebreaker88-- did you still want them?
if not
btt
Old November 19th, 2006, 12:02 AM   #10
junk90xj
ALLPRO AUTO
junk90xj's Avatar
if no one takes them i will.
http://www.apalansing.com/
junk90xj is offline
Old November 19th, 2006, 05:21 PM   #11
Icebreaker88
No sorry these wont work for me.
Old November 25th, 2006, 11:44 AM   #12
xjmichigan
xjmichigan's Avatar
ttt
Old December 8th, 2006, 08:55 PM   #13
xjmichigan
xjmichigan's Avatar
what ever happened to the 4 people that were very interested in these, then nothing.
BTT
Old December 10th, 2006, 09:48 AM   #14
ericschmidt
ericschmidt's Avatar
PM sent, Alan, I called you just before 11am Sunday. Gimme a call whenever you get a chance. Thanks!
Eric
ericschmidt is offline
Page generated in 0.32414 seconds with 65 queries
