99 Cherokee Sport High Idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2014, 01:45 PM   #1
jdeff87
jdeff87's Avatar
Default 99 Cherokee Sport High Idle
I just bought a 99 Cherokee sport has high idle. i have replace the IAC ( idle Air Control) TPS ( throttle Position Sensor) And cleaned the Intake. Any advice?
jdeff87 is offline   Reply With Quote
Old March 20th, 2014, 02:05 PM   #2
warner
oops, shit happens.....
warner's Avatar
check for vacuum leaks, and there is a adjustment screw on the throttle body that you can adjust.
warner is offline   Reply With Quote
Old March 20th, 2014, 02:48 PM   #3
jdeff87
jdeff87's Avatar
Checked all vacuum leaks and intake leaks by spraying carb cleaner around intake rpms didn't go up or down and there's not a screw to adjust the idle
Old March 20th, 2014, 09:51 PM   #4
warner
warner's Avatar
Old March 20th, 2014, 09:57 PM   #5
Toyfish
Toyfish's Avatar
Most likely tps
Sent from my DROID X2 using Tapatalk 2
Old March 21st, 2014, 11:45 AM   #6
jdeff87
jdeff87's Avatar
still dont control it. had a computer hooked up to it and i cant control the air in or air out. would the pcm be shorted out?
Page generated in 0.18986 seconds with 41 queries
