Excursion transmission problem-SOLVED - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 19th, 2014, 09:08 AM   #1
unclemyke
Default Excursion transmission problem-SOLVED
UPDATE : I found a 100k mile trans. Put it in, and everything works as it should, except.......when it shifts into drive, and o/d, it shakes and shudders under load. I've read a few things on the ol' Web, but I'd really like your thoughts.
unclemyke is offline   Reply With Quote
Old March 19th, 2014, 05:15 PM   #2
fordbronco
the ocean called
fordbronco's Avatar
No, they put them in both gas and diesel super duty trucks and excursions. 99-03 diesel super duty and excursion. Every year gas excursion I think?? They moved to the torque shift with the 6.0.
Old March 19th, 2014, 05:20 PM   #3
unclemyke
What about bellhousing? I've got the 5.4
Old March 19th, 2014, 05:31 PM   #4
insaneoffroader
insaneoffroader's Avatar
check rockauto.com they sell complete transmissions for Excursions. Just happened to be looking at them yesterday while ordering a rear window.
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old March 19th, 2014, 05:36 PM   #5
fordbronco
the ocean called
fordbronco's Avatar
Where are you looking for transmissions at? Considering any local stuff?
Old March 19th, 2014, 05:37 PM   #6
unclemyke
That's a big no good buddy..... Lol. Not payin' 2g's for a "new" trans. I'm looking for a used one in the $500(or less) range. There's GOTTA be a TONIGHT out there! I just can't find one.
Old March 19th, 2014, 07:06 PM   #7
fordbronco
the ocean called
fordbronco's Avatar
junkyard
Old March 19th, 2014, 08:01 PM   #8
unclemyke
All I've found under 100 miles away has like 230k on it for $550 + core. I thought these things would be plentiful.....guess not. Think I found one down in Ohio.....200 miles away!
Old April 5th, 2014, 03:00 PM   #9
unclemyke
Update.
Old April 5th, 2014, 08:51 PM   #10
blackbronco92
300 Inline 6
blackbronco92's Avatar
Torque converter shudder. One of the most common problems for Ford. Try lightly applying the brake with your left foot while holding steady on the throttle with your right while it is shuddering.
Lightly applying the brake, just enough to turn the lights on, will take the converter out of lockup. If the shudder goes away, it's a good sign your converter is bad. My '94 F-150 has the same issue - feels like driving over rumble strips when under load in lockup.
blackbronco92 is offline   Reply With Quote
Old April 11th, 2014, 08:29 AM   #11
unclemyke
Problem solved gentlemen! Was getting a misfire on call 1. Replaced the coil, and viola! It was missing so bad that it was bucking which I mistook for converter shudder. Yay!
Page generated in 0.33405 seconds with 56 queries
