Engine builders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2014, 06:26 PM   #1
Carbon
Yooper
Carbon's Avatar
Default Engine builders
Looking to get my race engine built. I have a running sbc 350 and am looking for some specific work to be done on it. Lets hear who you have used. Northern Michigan/Upper peninsula preferred.
Some people just need a high five. In the Face. With a chair.
Carbon is offline   Reply With Quote
Old March 17th, 2014, 06:44 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I don't have a clue that far north, but I can recommend a few in the Grand Rapids/Muskegon areas.
Old March 17th, 2014, 07:02 PM   #3
Carbon
Yooper
Carbon's Avatar
Thanks SANDVIPR thats a little to far for me.
Old March 17th, 2014, 07:06 PM   #4
Grassman
2jz specialist
Grassman's Avatar
if you have beefy do it he will start by torching the first 4 cyls off and work from there
Old March 17th, 2014, 07:11 PM   #5
Carbon
Yooper
Carbon's Avatar
I'd like to keep all 8 cylinders if possible.
Old March 18th, 2014, 08:00 AM   #6
jonzer12
My buddy just had his race engine built by some place near Bay city. I can ask him for the info if you want.
jonzer12 is offline   Reply With Quote
Old March 18th, 2014, 08:26 AM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
What the fukc
Old March 18th, 2014, 08:30 AM   #8
Grassman
2jz specialist
Grassman's Avatar
Old March 18th, 2014, 08:37 AM   #9
Carbon
Yooper
Carbon's Avatar
Originally Posted by Mr. Beefy View Post
What the fukc
You like making 4.3's?
Old March 18th, 2014, 08:39 AM   #10
Grassman
2jz specialist
Grassman's Avatar
figuratively yes, yes he does
Old March 18th, 2014, 08:43 AM   #11
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I think I'm being profiled.
Old March 18th, 2014, 08:44 AM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
what was this thread about?
H.o.r.e
Old March 18th, 2014, 01:15 PM   #13
Carbon
Yooper
Carbon's Avatar
Oh yeah I remember now. It was about getting my engine work done. All I know is I don't really want a 4.3 in my truck so hacking off two cylinders isn't really what I am looking for. Thanks though Beefy.
The bottom would be stock but would like it refreshed and cylinders would be bored over. Flat top pistons and cam installed. Would need a set of vortec heads rebuilt to my spec.
Its a very simple build but I want it done right. Here are the 2014 rules.
http://www.usacracing.com/assets/fil...StockTruck.pdf
18. ENGINE
"Stock" means the part or assembly in its "as cast" configuration as delivered and used on U.S. model without modifications. All casting and/or part numbers must be visible.
Allowed:
A. Engine must be in stock location on stock mounts for a V-8.
B. One engine movement limiter-cable, chain etc.
C. Strengthening of the motor mount brackets by additional material only.
D. Motors other than those listed may be used once approved by TORC Series Tech.
Not Allowed:
A. Any modification not specifically listed.
B. Mounting plates.
19. BLOCK AND CRANKSHAFT
Approved standard OEM, as cast iron production block.
Blocks approved by TORC Series are:
GM 350,
Mopar.360
Ford 351 Windsor.
A. Stock cast or forged steel crankshaft or OEM aftermarket replacement only.
B. Rod journal grind is open but all the following engine rules must be adhered to.
Required:
A. 3/4 inch inspection hole in the side of the oil pan, in line with crankshaft journal and crankshaft casting number.
B. Stock block deck height within .020 of specification.
C. Maximum 370 cubic inch displacement.
D. Engines must be able to be sealed once they are pumped. One head bolt, one intake manifold bolt, one oil pan bolt on each side of the oil pan must be drilled to allow sealing.
Allowed:
A. Blue printing and balancing.
B. Using studs rather than bolts.
C. Oil pan windage trays.
D. High volume or pressure oil pump.
E. Auxiliary engine oil cooler.
F. Fan for oil cooler.
G. Remote oil filters.
H. Harmonic balancer open, any manufacturer. Must be SFI 18.1 approved
Not Allowed:
A. Any kind of modification specification not listed above.
B. Crankshafts that have been knife edged or lightened.
C. Dry sumps or external wet sump pumps are not allowed.
20. CYLINDER HEADS AND VALVES
A. Standard production, as cast, iron heads that matches the block with the casting numbers clearly visible.
B. GM may use any OEM production head with a maximum intake valve diameter of 1.94, maximum exhaust valve diameter of 1.60. No angle plug or bowtie heads allowed.
C. Chrysler may use any OEM production head including the magnum head part # P5007086. W-2 heads not allowed. Maximum intake valve diameter of 1.88, maximum exhaust valve diameter of 1.60.
D. Ford may use any OEM production head, GT40, GT40P or World Products Roush 180 part No. 5303, Maximum intake valve diameter of 1.94, and maximum exhaust valve diameter of 1.60.
Allowed:
A. After market valve springs provided the stock outside dimension is retained.
B. Three angle valve jobs.
C. Single 45 degree cut on the valve face.
D. Valve guide material unlimited.
E. Stainless steel valves.
F. Screw in studs and guide plates.
G. One breather per valve cover.
H. Machining of head to accommodate valve size listed above.
Not Allowed:
A. Any modifications of the cylinder head not specifically listed above.
B. Angle milling/cutting of the block or cylinder heads.
C. Bowl cutting.
D. Titanium or composite valves.
21. PISTONS AND CONNECTING RODS
Allowed:
A. Flat top or dished, stock or OEM replacement piston only. Cast or forged pistons.
B. Steel rods with stock dimensions only: gm-5.791, Mopar-6.123, And Ford-5954.
C. Removal of casting flash from connecting rod, shot peen of connecting rod.
Not Allowed:
A. Any modifications not specifically listed above.
B. Titanium, stainless, aluminum, H beam etc rods.
C. No domed or notched pistons.
D. Piston must remain at or below deck height at TDC.
22. CAM AND LIFTERS
Stock type cast flat tappet camshafts with a maximum valve lift as measured at the valve of .500. Stock lifter bore size.
Allowed:
A. Other cam grind specifications are unrestricted.
B. Full roller rockers, stud mount only.
C. After market direct replacement timing chain and gears.
Not Allowed:
B. Roller mushroom type lifers.
C. Gear or belt drive.
D. Shaft type rocker unless OEM.
23. INTAKE MANIFOLD
Allowed:
A. As cast-Edelbrock intake: part number, GM 5001 or 2716, Mopar 5076, Ford 5081.
B. Match porting by the removal of material only, within the last inch of the runner only.
C. Addition of return water port in rear of intake manifold allowed, but must be approved by TORC Series Tech.
D. Machining of intake to match Vortec head.
E. Standard design gaskets only.
F. Drilling of head to install intake allowed, must be approved by TORC Series Tech.
Not Allowed:
A. Any other modification not specifically listed above.
B. No devices between the carburetor and the intake manifold, designed to increase or redirect airflow will be allowed.
24. CARBURETOR
Required:
A. One two-barrel model number 0-4412 and one combination restrictor plate/spacer assembly with two 1.375 bores. Must be used with standard size gaskets only. This unit is available though TORC Series tech only!
B. Fuel pump- mechanical only in the stock location
Allowed:
Removal of choke plate.
Not Allowed:
A. Any modification in/to the throttle bore.
B. Any modification to the TORC Series restrictor plate.
Old March 18th, 2014, 01:31 PM   #14
frdboy
frdboy's Avatar
The power is gonna be in the piston/ring pack and cam.....don't go cheap there.
Old March 18th, 2014, 03:49 PM   #15
Carbon
Yooper
Carbon's Avatar
Thanks frdboy.
Old March 18th, 2014, 04:50 PM   #16
jonzer12
http://www.mccarthyperformance.com/Services.html
You can try this guy. He has built a bunch motors for locals here.
Old March 18th, 2014, 05:27 PM   #17
Carbon
Yooper
Carbon's Avatar
Thanks. Trying to get as local as possible.
Old March 18th, 2014, 06:58 PM   #18
I suck cocks. Lots of them.
locally famous
Bill Plain is a legend, and he has recently relocated/semi retired to vanderbilt. If you meet him, you will look no further. Built 5 or 6 for me in the last 15 years. Class act, top notch.
Old March 19th, 2014, 07:36 AM   #19
Carbon
Yooper
Carbon's Avatar
Thanks Marshall. I will look into this guy.
Old March 19th, 2014, 11:48 AM   #20
AFRd_CJ5
AFRd_CJ5's Avatar
I agree here. There's no way I'd be getting any off the shelf cam for this setup. I'd be contacting some well known cam grinders and get something built.
What heads are you looking at using?
AFRd_CJ5 is offline   Reply With Quote
Page generated in 0.45732 seconds with 83 queries
