62cm DeSalvo semi-custom track bicycle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2014, 08:23 PM   #1
bigmatt
Default 62cm DeSalvo semi-custom track bicycle
This is a semi-custom compact road geometry De Salvo Track bike. http://www.desalvocycles.com/bikes/steel-track/ It has a sloping top tube and is considered his "58cm" size. It ends up being an effective seat tube of 62cm and an effective top tube of 61.5cm. The frame finish is called the nude finish. It is an awesome finish that shows some of the weld and brazing marks from building the frame.
Features:
front triangle is Columbus Zona with Life chain and seat stays
Thomson seat post
Thomson X4 stem
Nashbar saddle (Fizik Arione knock off)
Ritchey comp thread less headset
Salso Pro road bars 31.8 clamp size
Tektro Aero brake levers
Black slightly mismatched 105 brake calipers front and rear
Truvativ Omnium 170mm 48t track crank with GXP BB
Shimano 105 road pedals (Look delta cleats)
Pair of Stainless Steel bottle cages
Continental GP 4000 tires in black/grey
36 hole Formula hubs laced to Velocity Aerohead rims. Rear hub is double fixed. Rear is laced 3 cross and front 1 cross. Surly 17t 1/8" cog and locking on the drive side. The non-drive side has a Dura Ace cog and lock ring.
Sold
bigmatt is offline   Reply With Quote
Old April 14th, 2014, 11:59 AM   #2
bigmatt
bump
Old July 2nd, 2014, 02:54 PM   #3
bigmatt
Drop to $1000.
Page generated in 0.19219 seconds with 32 queries
