15" Wheels on 1 ton - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2006, 05:19 PM   #1
mud22
mud22's Avatar
Default 15" Wheels on 1 ton
Can 15" rims be used on a front Chevy Dana 60 and rear 14 bolt 1 ton. If so, how much offset or backspacing do I need?
mud22 is offline   Reply With Quote
Old November 14th, 2006, 07:38 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
They will fit. You will just make good friends with mr. grinder.
Old November 14th, 2006, 08:47 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
The rear will be fine with the 3" offset.. the front you will have to grind, and watch the caliper it is easy to grind to much when you get close. Do a lot of trial fits and spray paint before testing. That will show you where to grind when it gets close enough. Have fun remeber safety glases and you should use a mask. It will take some time.
Page generated in 0.20029 seconds with 32 queries
