WJ: death wobble issues fixed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2014, 11:23 AM   #1
newdodge
jeep life
newdodge's Avatar
Angry death wobble issues fixed
death wobble issues I have a 2000 brand new 4 inch Rough Country lift new lower arms track bar shocks adjustable track bar new sway bars which are just connects new tie rod ends drag link steering box arm steering stabilizer I have went through everything on front of my Jeep running be realigned 3 times so far I get death wobble from 45 and up only on the driver side front tire I cannot figure it out need help please before I blow this thing up
newdodge is offline   Reply With Quote
Old March 8th, 2014, 11:31 AM   #2
Andy456123
Guest
If the kit is brand new and installed correctly, I would look at the mounts on the jeep and see if any of holes are egged out. I'm talking about the control arm and track bar mounts, both on the frame and on the axle.
If you did not replace the upper control arms, check those bushings.
Most of my experiences with death wobble have been track bar related.
Andy456123 is offline   Reply With Quote
Old March 8th, 2014, 12:00 PM   #3
newdodge
jeep life
newdodge's Avatar
I have checked all ball joints will be arranged upper and lower control arm are tight holes were not walk without want to talk of the lower control arms track bar holes are good night wobble doubt I will check the upper control arm bushings
Old March 8th, 2014, 02:02 PM   #4
t_ank
t_ank's Avatar
Check the balance of the tires also
t_ank is offline   Reply With Quote
Old March 8th, 2014, 03:02 PM   #5
newdodge
jeep life
newdodge's Avatar
yep I had that check to help
Old March 8th, 2014, 09:28 PM   #6
threeEs99
threeEs99's Avatar
Is the caster correct ? Wheel bearings?
threeEs99 is offline   Reply With Quote
Old March 8th, 2014, 09:30 PM   #7
firehawk
Live Action!
firehawk's Avatar
Is there a nut behind the wheel?
Old March 8th, 2014, 09:49 PM   #8
88yjproject
Ha, exact reason I took my 4.5" kit off. Some people have no problems what so ever. Others can't seem to find the cause even when everything has been replaced.
88yjproject is offline   Reply With Quote
Old March 8th, 2014, 09:50 PM   #9
kickstand
circling the drain
kickstand's Avatar
I wonder if anyone else has ever had death wobble before....I swear I think I saw a thread on this once with all the things to check....I must be imagining it all.
Old March 8th, 2014, 10:01 PM   #10
Andy456123
Guest
between this guy, 2fists4me, and jizzdonkey, i would just like to remind you all that the answer you get is not the one you might want to hear.
thank you, and good day sir!
Old March 8th, 2014, 10:47 PM   #11
Lousypirate
Whoop Whoop
Lousypirate's Avatar
What is your caster angle?
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old March 8th, 2014, 11:19 PM   #12
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
Sell it.
concreteguy82 is offline   Reply With Quote
Old March 9th, 2014, 03:51 AM   #13
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Did you get it?
H.o.r.e
Old March 9th, 2014, 08:13 AM   #14
newdodge
jeep life
newdodge's Avatar
the wheel bearings are good I will have to check for the caster angle
Old March 9th, 2014, 08:14 AM   #15
newdodge
jeep life
newdodge's Avatar
I will look
Old March 9th, 2014, 08:20 AM   #16
firehawk
Live Action!
firehawk's Avatar
I will look
Check in the rear view mirror!
Old March 9th, 2014, 08:23 AM   #17
firehawk
Live Action!
firehawk's Avatar
Check tire pressure and adjust if necessary and check the track bar mounting points and bushings for slop.
It took me a while to get it dialed out of my TJ on a 4.5 RE lift but I got dat sumbitch!
Old March 9th, 2014, 10:43 AM   #18
newdodge
jeep life
newdodge's Avatar
okay I will try that the track bar is brand new its only 2 days old I will look at everything that you said I'll let you know thank you
Old March 9th, 2014, 10:44 AM   #19
newdodge
jeep life
newdodge's Avatar
lol
Old March 9th, 2014, 10:46 AM   #20
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Brand new track bar doesn't mean a thing. Make sure that sumbitch is TIGHT
Page generated in 0.46069 seconds with 84 queries
