Gear ratio mis match - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2014, 09:07 AM   #1
Nitrodave
Default Gear ratio mis match
Have a lead on a 9" ford rear axle to stuff under my cj7. The axle tag shows as a 3.50 ratio. Would this be far enough off from a 3.54 ratio in the front to cause a problem ?
Nitrodave is offline   Reply With Quote
Old March 8th, 2014, 09:12 AM   #2
I suck cocks. Lots of them.
locally famous
Run it
Old March 8th, 2014, 09:16 AM   #3
in2deep
Hole tester
it will be fine
Old March 8th, 2014, 09:18 AM   #4
kickstand
circling the drain
kickstand's Avatar
you're fucked
Old March 8th, 2014, 09:20 AM   #5
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
Do it to it
concreteguy82 is offline   Reply With Quote
Old March 8th, 2014, 09:34 AM   #6
ljense8
Web Wheeler
ljense8's Avatar
As long as you only use 4x4 in mud/snow/sand you should be ok. Your rig might get a little tail happy though.
ljense8 is offline   Reply With Quote
Old March 8th, 2014, 09:49 AM   #7
Toyfish
Toyfish's Avatar
I think i read somwhere u should keep it within a 10% difference and ur pretty close so it should work
Sent from my DROID X2 using Tapatalk 2
Old March 8th, 2014, 10:23 AM   #8
skife
skife's Avatar
it'll be fine, i once ran 3.55 and 3.73 I wouldn't reccomend it.. but i did for awhile.
Old March 8th, 2014, 11:31 AM   #9
insaneoffroader
insaneoffroader's Avatar
Within 10% your OK. Ford from the factory ran 3.54 front and 3.50 rear In The 1970's vintage trucks
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old March 8th, 2014, 01:13 PM   #10
fordbronco
the ocean called
fordbronco's Avatar
Do it.
Old March 8th, 2014, 01:39 PM   #11
non issue
Old March 8th, 2014, 05:10 PM   #12
Nitrodave
Thanks..
Page generated in 0.31366 seconds with 59 queries
