Tire/rim size question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2014, 06:38 PM   #1
Wehan
Wehan's Avatar
Default Tire/rim size question
My cobalt has factory sized 195 60r15 tires and stock steel wheels. I found some decent aluminum wheels that have 185 55r15 on them. Are these rims most likely an appropriate width for my tires? Offset appears to be acceptable but I'm going to test fit one to be certain of bolt pattern and offset/brake clearance etc.
Wehan is offline   Reply With Quote
Old March 14th, 2014, 03:24 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
Those are both pretty small tires, I doubt you have a problem mounting a 5mm wider tire on the rim...
Old March 14th, 2014, 03:41 PM   #3
fordbronco
the ocean called
fordbronco's Avatar
Test fit it. What did the aluminum wheels come off of?
Old March 14th, 2014, 09:20 PM   #4
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
http://www.tacomaworld.com/forum/tirecalc.php
my fav site for these questions far as comparison
Old March 14th, 2014, 11:25 PM   #5
bbaXJ
Yooper In Training
bbaXJ's Avatar
It would be 10mm wider, unless you meant 5mm per side. I agree though, very unlikely to be an issue. That's just over 3/8" difference for the metrically challenged.
Old March 15th, 2014, 09:19 AM   #6
littletrucker
I'd hit that
I was thinking 190 to a 185, reread it 195-185 is 10mm, still not much.
Old March 15th, 2014, 10:12 AM   #7
Wehan
Wehan's Avatar
Thanks for the help guys, the rims were off a 97 Aveo. Seller flaked out at the last minute. All well more monies for my other hobbies.
Page generated in 0.16193 seconds with 44 queries
