Build my 727 trans - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2014, 12:29 PM   #21
Strangler
Strangler's Avatar
Put a Chevy in it.
Old March 10th, 2014, 12:38 PM   #22
Wramblerguy
Wramblerguy's Avatar
Add a third pedal
My trans never overheats
3rd generation jeeper
Old March 10th, 2014, 02:16 PM   #23
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Lol no Scott.
I enjoy the auto to much. When I had a manual, I hated it. Never lasted
Old March 10th, 2014, 04:09 PM   #24
v2win
v2win's Avatar
Do you have the kick down linkage installed and operating correctly or is it wired wide open? If its wired all the way open it will burn up bands.
Are you holding the trans in low gear when you are in hi range in the tcase? It needs to shift or it will overheat.
v2win is offline   Reply With Quote
Old March 11th, 2014, 11:05 AM   #25
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Cable operates perfectly and moves freely throughout the total range of motion.
I pick the highest gear the rpm allows when off road.
I'm calling companies for a tc, tci recommended a 2400 stall they sell. Looking into edge now.
My cooler lines look like they could be opened up a lot. I'm sure running 1/2 line will free up some flow. The h-pipe runs rite behind the trans pan....while I wrapped it, I'm sure that isn't helping my issue.
Old March 12th, 2014, 12:37 PM   #26
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Well inspected all parts.....broken bellvile spring in 3 pieces, two front clutches to bare metal on the ends...the other have barley ant friction material left, crack on the input shaft.
Page generated in 0.33526 seconds with 41 queries
