Bad shocks on caravan? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2014, 05:36 AM   #1
jimhri
jimhri's Avatar
Default Bad shocks on caravan?
2010 caravan, 3.3 auto trans, 62000 mi. rattle noise sounding like a loose bolt on the trailer hitch (which it is not) from rear wheel well area over even minor bumps in city pavement. possible the piston on a worn shock would "rattle"?
jimhri is offline   Reply With Quote
Old March 4th, 2014, 05:46 AM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Sway bar bushing/link?
Old March 4th, 2014, 06:03 AM   #3
crazykev
crazykev's Avatar
blown out strut possibly
crazykev is offline   Reply With Quote
Old March 4th, 2014, 07:01 AM   #4
fordbronco
the ocean called
fordbronco's Avatar
This
Old March 4th, 2014, 07:03 AM   #5
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Originally Posted by fordbronco View Post
This
x2.
Also, check the bushings of the lower arm.
Old March 4th, 2014, 07:16 AM   #6
I suck cocks. Lots of them.
locally famous
Does it live in a warm garage, or is it covered in frozen hell like most every other vehicle on the road?
Old March 4th, 2014, 07:31 AM   #7
Toyfish
Toyfish's Avatar
This or a blown out bushing in the shock
Sent from my DROID X2 using Tapatalk 2
Old March 4th, 2014, 09:22 AM   #8
fordbronco
the ocean called
fordbronco's Avatar
No struts in rear. OP, what have you found?
Old March 4th, 2014, 11:32 AM   #9
jimhri
jimhri's Avatar
Default RESOLVED ~ bad shocks, caravan
a bolt securing the brake caliper sheared, causing it to rattle when hitting bumps. replace caliper, brake pads, brake fluid lines flushed. all is now quiet.
THANKS for your suggestions. i did not sound like the village idiot when speaking to mr. fixit at the repair shop.
Page generated in 0.22316 seconds with 50 queries
