Swapped out chain in np231 of 97 wrangler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2014, 08:58 PM   #1
gattaca37
gattaca37's Avatar
Default Swapped out chain in np231 of 97 wrangler
Tcase chain in 97' wrangler
Noticed some slop in chain of np231
Ordered a crown oem replacement from jegs
Installed, (what a pain), an wondering if there is a break in for the chain?
I noticed it was a pain to install the new chain bein that it's not stretched. I took jeep for a drive in 2h an noticed that chain just seems too tight an is robbing horsepower. I matched the chains up for comparison before install an they were same links an same lengths. Jeep has an hack an tap for the sye
I had to remove seal, bearing of tail cone to get it on an a porta power to push shaft over for the bearing to reinstall. Went through all gears an 2h,4h an 4L
Went down the road in 2h for a test an noticed power loss as I go through the manual gear pattern an feel the engine trying to build revs but it feels as if the chain is restriction the shaft to obtain the desired speed
Everything inside is together the same as it was before I swapped out chain
I asked the jeg rep multiple times if this was the correct chain an he said yes
The box says 87-06 wrangler on it
Just confused an wondering if there is a break in to get some relief on the new chain.
New chain shouldn't be that tight?
gattaca37 is offline   Reply With Quote
Old March 2nd, 2014, 09:27 PM   #2
Tab
Tab's Avatar
No, it shouldn't. I would take it apart again and see what is wrong.
Old March 3rd, 2014, 10:54 AM   #3
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
x2
CHEVYRCKS is offline   Reply With Quote
Old March 9th, 2014, 12:00 AM   #4
gattaca37
gattaca37's Avatar
Pulled apart
Took crown off compared to old one
Crown looked shorter which it should cause new
Compared crown to new alloy USA
Looked similar
Put stock back on as a mock up, everything fit perfect
Put alloy USA on as a mock up, perfect
I applied gasket maker an reassembled with alloy USA chain an both ended of the tcase turned smoothly
Done deal
Only thing I can figure is the crown was very similar but not the right chain, someone at factory threw wrong chain in right box
Page generated in 0.25856 seconds with 35 queries
