School me on antifreeze - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2014, 08:17 PM   #1
Default School me on antifreeze
I've always used the green stuff. I just put my radiator back in and realized I bought the orange glycol stuff. Somewhere I heard the 2 are incompatible but I don't see anything on the jug.
So, compatible or not, one better than the other, where applicable or not?
So teach the old guy.
Old February 25th, 2014, 08:19 PM   #2
We use gl-5, more of a yellow. Suppose to interchange with any kind. I run from the orange lol.
Old February 25th, 2014, 08:22 PM   #3
firehawk
Live Action!
firehawk's Avatar
They usually say if they are compatible with any make and model. Unless you bought the GM stuff I think.
Typically they are not mixable unless you have the new stuff that is compatible with all makes and models which most of the new stuff is.
I would not use it in a high end vehicle that call for some special blue or pink stuff.
If you want to use what you have and are worried about it just flush the whole system and use whatever you want.
I have read to use the green over the orange and I have seen what the orange stuff can do in certain situations, not sure if the new stuff has that issue or not.
But the orange stuff is supposed to go longer between flushes.
So what vehicle are you working on?
Old February 25th, 2014, 08:24 PM   #4
firehawk
Live Action!
firehawk's Avatar
I have used that yellow stuff, guaranteed to work with everything supposedly and we pumped it out of a 55 gal barrel.
Old February 25th, 2014, 08:46 PM   #5
1 ton tj on 40's
1 ton tj on 40's's Avatar
his jeep.
if you use the orange stuff I would do a good flush.
Old February 25th, 2014, 08:51 PM   #6
Yup, the jeep. I would rather use a universal coolant that can be mixed & matched on the trail versus something special. The jug just says it's good for any vehicle that specifies dex-cool.
What happens if it gets mixed?
Old February 25th, 2014, 08:51 PM   #7
Toyfish
Toyfish's Avatar
Stay away from the orange stuff i assume its dexcool we use global antifreeze at work its universal and will mix with anything
Sent from my DROID X2 using Tapatalk 2
Old February 25th, 2014, 08:52 PM   #8
GREASYHANDS
GREASYHANDS's Avatar
Fawk dexcool. Green stuff rules
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 25th, 2014, 08:53 PM   #9
GREASYHANDS
Mud and corrosion
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 25th, 2014, 09:04 PM   #10
frdboy
frdboy's Avatar
I would stay with green or yellow....they can be be mixed and the yellow normally says it is universal. Unless you are gonna completely flush the system and switch to DexCool...I would not mix a DexCool branded coolant as it is not recommended to mix them. Some manufactures are using orange dye in their universal coolant so you can't go by color alone.
We probably have 10 different coolants at the shop to cover everything as we only use a coolant that is approved my the vehicles manufacture.
Old February 25th, 2014, 09:48 PM   #11
firehawk
Live Action!
firehawk's Avatar
Don't use the Dex Cool unless that is what was in there. But then you can flush it and put the other stuff in there.
Old February 25th, 2014, 10:27 PM   #12
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
What's wrong with the orange GM dexcool?
Old February 25th, 2014, 11:00 PM   #13
firehawk
Live Action!
firehawk's Avatar
Google it.
Many issues, some were from bad cooling systems but it sludges up and some rubber gaskets from GM gets eaten away from it.
Old February 26th, 2014, 05:16 AM   #14
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Google it.
It's hard to google with a slow as fawk phone
Good to know thanks. That's what i run right now. I'll have to look into it and see if it's worth doing a flush and changing fluid.
Old February 26th, 2014, 05:20 AM   #15
Google it.
I didn't want to google it cuz you guys are so much wiser.
Thanks for all the input. Anybody want to buy a freshly opened jug of dex cool cheap?
Old February 26th, 2014, 05:51 AM   #16
frdboy
frdboy's Avatar
What kind of vehicle? Chrysler uses a orange coolant but it is not DexCool.
Best thing you can do if you have DexCool (or any other really) is to make sure it does not get low and the radiator cap is in good condition.
Old February 26th, 2014, 06:05 AM   #17
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I've heard sex cool gets nasty when old and starts eating gaskets.
Old February 26th, 2014, 06:05 AM   #18
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Default if for Chrysler...
The coolant that is approved for 2001 and newer Chryslers is a HOAT formula.
The only aftermarket approved MS-9769 spec coolant is ZEREX G-05 spec coolant.
So sayeth Chrysler forums.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old February 26th, 2014, 10:13 AM   #19
kkodet
kkodet's Avatar
Adding to the many issues of Dex-Cool, part of the issue is corrosion of aluminum parts.
Also, this is from personal experience and some experience of other mechanic associates of mine. It seems a magic combo for destruction is to take a GM vehicle with 70-150K on it and flush out the original Dex-Cool. Then put in new Dex-Cool. In my own personal experience more than half a dozen times, right after doing that within a week or two I've had some sort of gasket failure, usually intake or water pump. From what I have gathered it has something to do with acidity or possibly alkalinity.
Old February 26th, 2014, 10:34 AM   #20
Rob the plumber
dexcool is how my Chebbie van got a new engine. Intake gasket went away.
Page generated in 1.12175 seconds with 83 queries
