4.5 stroker - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2014, 08:14 AM   #81
I would say to look into a SC3800 but it takes premium.
Old February 27th, 2014, 10:19 AM   #82
kickstand
circling the drain
kickstand's Avatar
Originally Posted by 2fst4you View Post
I don't see what's so wrong with my plan and questions
Yes, we understand that you don't see why you're fucktarded. That's about 90% of why you are fucktarded.
Old February 27th, 2014, 10:48 AM   #83
bigbchevy
missmrgreenagain
bigbchevy's Avatar
You should look for a ford 5.0.
H.o.r.e
Old February 27th, 2014, 10:51 AM   #84
Cartman
Can't lose with 42s
Cartman's Avatar
For $300 more id be ok with 20hp
when reality calls answer the phone k
Cartman is offline   Reply With Quote
Old February 27th, 2014, 11:00 AM   #85
Quote of the month nomination
Old February 27th, 2014, 01:24 PM   #86
firehawk
Live Action!
firehawk's Avatar
Good lord!
Old February 27th, 2014, 01:45 PM   #87
bigbchevy
missmrgreenagain
bigbchevy's Avatar
yes....... I love this place
H.o.r.e
Old February 27th, 2014, 03:09 PM   #88
2fst4you
2fst4you's Avatar
I seen a used Coyote motor go for under $200, I would look into ford 5.0's
I don't want a ford motor and not sure how what all would be involved in making it work
Originally Posted by cj65 View Post
If all else fails I have a good running 225cid slant 6 form a 1963 dart!
Not going smaller lol
I'm ok with running premium just would rather not.
I really don't get everyone's problem I'm rebuilding my 4.p and thought I might as well do a simple stroker. I don't see a problem with asking questions and considering it
Old February 27th, 2014, 03:33 PM   #89
montecarlo33
The Violator
montecarlo33's Avatar
problem is this is like the 3rd thread you've started on this smokey engine of yours and they are all filled with the same shit. You want the gains, without the cost or work which doesn't happen in this world. Just fix whats wrong and keep wheeling or whatever you do. Instead of asking so many questions here, just take them to google and spend some time reading/learning what others did and make your own plan.
Old February 27th, 2014, 03:45 PM   #90
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Then why no response to this?
Originally Posted by JohnnyJ View Post
What's wrong with this recipe? Pics are gone, text is still there.
Full 4.6 stroker build write-up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2014, 03:49 PM   #91
kickstand
circling the drain
kickstand's Avatar
nonsense.
Old February 27th, 2014, 04:05 PM   #92
Cartman
Can't lose with 42s
Cartman's Avatar
It's not simple
Your goals aren't realistic neither is your budget
Old February 27th, 2014, 05:09 PM   #93
lgottler
lgottler's Avatar
Thanks for that link!
lgottler is offline   Reply With Quote
Old February 27th, 2014, 08:34 PM   #94
wakeboard76
wakeboard76's Avatar
Keep in mind with that build, he was using the older (pre HO) computer and wiring, which I believe had a knock sensor and can compensate a little better. The same build with a newer computer and wiring may not work as well.
wakeboard76 is offline   Reply With Quote
Old February 27th, 2014, 10:52 PM   #95
2fst4you
2fst4you's Avatar
I just wanted to know if I could run stock pistons with the 258 crank and rods successfully. If its requires boring the cylinder and gets too expensive I will just rebuild it as is. I have some money to spend just not gonna spend a fortune on a 4.0 when I could save for a 5.3. I am willing to do the work and plan to once it warms up
I looked at it as well as numerous stroker builds I just had that one specific question for the most part and it let to this. I may go that route depending on cost
Old March 15th, 2014, 07:19 AM   #96
cerial
1200PSIg Double acting
cerial's Avatar
Running a 4.5 engine with stock transmission/transfer case gears is just stupid.
20hp could be made through bolt on mods. While installing 4/1 gears will be noticed. Then you could install taller gears in your axles or axles with taller gears and get a (slight) mileage increase while having a better craw ratio then stock.
This is from experience through starting with a pos 999 3 speed, installing a Cherokee 4 speed, then installing a 5 speed. Gearing to keep the engine within the power range while making more power through that gearing works.
Having the transfer case set up to make torque when needed works.
Turning your engine into a "stroker" to make next to no gains does not work.
Old March 15th, 2014, 01:36 PM   #97
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
one specific question that could be answered with 15 minutes on google.
dont put money into a flat tappet motor. my stroker as well as every other one ive seen has had cam issues within 100k miles, some farther away from that figure than others. by the time you invest in roller lifters and rockers, and get all the bells and whistles to do a stroker... youve got a highly modified tractor motor that no longer has the reliability of a stock motor. and when you compare HP/$, you could have easily dropped in a 5.3L.
but a 5.3 costs too much, right? you think the stroker is cheaper? it only looks like it because, as someone said, your budget is unrealistic. you want cheap? drop in another 4.0 and be happy. you can find them for <$500 and itll only take a day or two of work. but im sure that task will be rough enough for you. better get to posting threads about what plug goes where and "lefty, tighty, right?"
VAhasnoWAVES is offline   Reply With Quote
Old March 15th, 2014, 09:59 PM   #98
fordbronco
the ocean called
fordbronco's Avatar
watz a geep?
Page generated in 0.31458 seconds with 77 queries
