4.5 stroker - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2014, 03:06 PM   #61
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Nobody surpasses your levels of stupidity, hording, ADD, and attention whoring. No one.
Hail to the king baby!
I'm the man in White.
Old February 26th, 2014, 03:21 PM   #62
Originally Posted by lgottler View Post
Used that need to be pulled, then scrap rest, hope they are in good shape, send out to grind..... vs. In a box new? Is this the price difference?
True, but if you have that attitude, then you don't say thiings like "these bearings only have 110k miles on them, why do I need to replace them even though I have the engine apart?"
I've got a couple 258s, and was thinking of this, or a 4.0 head on my nice-running 258 in my CJ7, just to do something different. Just hard sorting through all the gotchas on either of these options. There's always the little things that aren't quite compatible, and like 3 different ways to deal with thme, which might or might not be the right way. Valve springs, fuel injectors & pressure, piston quench, crank snout length, pilot bearing, etc...
Old February 26th, 2014, 03:28 PM   #63
cj65
cj65's Avatar
[QUOTE=2fst4you;3656345]You know nothing Joe
What would you suggest I do to the head?
Port and polish the exhaust ports. And port the intake ports but dont over polish them. The intake ports needs to be semi rough to allow the air fuel mixture to atomized. Then a bit of bowl work to blend them into the port. And some combustion chamber work. Along with a good vvalve job. That will yield more power than stroking the engine. A good bumpstick and new rings and bearings. As long as your cylinder walls dont have a huge ridge just rering it and use your stock pistons if they are in good shape.
Just remember that when bulding a engine cleanliness is next to godliness.
Old February 26th, 2014, 03:59 PM   #64
Why not just put a 5.3 in?
Old February 26th, 2014, 04:03 PM   #65
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
He is going to work his way up to it eventually... After a 4.5 stroker and then a 4.8.
Old February 26th, 2014, 04:23 PM   #66
kickstand
circling the drain
kickstand's Avatar
He hasn't even gotten over 4.2 liters yet, slow down, this takes baby steps.
Old February 26th, 2014, 04:31 PM   #67
2fst4you
2fst4you's Avatar
At first I thought I would individually respond to some of the things you said. But instead I think this will cover it.
You need help, like skooterbuilt levels of help. Stop posting.
hahahahahaha
I don't see what's so wrong with my plan and questions
Originally Posted by Wramblerguy View Post
Why would you spend 3-400 on a 258 crank and rods when I see whole motors go for 200 or less all the time
Find me a good running motor for $200.....if you can which you won't I won't be interested I want less than 100k on it
Exactly
Old February 26th, 2014, 04:36 PM   #68
2fst4you
2fst4you's Avatar
I didn't say anything about not changing the bearings I asked why the pistons needed to be replaced.
[quote=cj65;3656486]
Ok thanks!
I don't have the money right now just figured id make a lil more power out of my 4.0 while I have it apart
Rebuild 4.0 possibly making it a 4.5 then 5.3 some day. Atleast I actually wheel joe and don't want to take my 35s off to make it a plow truck on 33s
Old February 26th, 2014, 04:38 PM   #69
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Does the 4.0 still run fine? Keep running it, save for 5.3
/thread
Thanks for wasting everyone's time. Bye
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old February 26th, 2014, 04:54 PM   #70
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I have a goldfish.
Old February 26th, 2014, 05:28 PM   #71
2fst4you
2fst4you's Avatar
/thread
It runs fine but burns oil badly. Smokes horribly and I want to fix that
Old February 26th, 2014, 05:50 PM   #72
cj65
cj65's Avatar
If thats all it is its most likely valve guides and seals. Redo the head or buy a new rebulit head and be done with it. Rings could be worn but highly unlikely. When the heads off take a look at the cylinder walls and see if there is a major ridge. If there is then rering it also. If it was mine id re bearing and ring it with new oil pump and a rebulit head. Then run it till u have the cash for a 5.3 swap.
Old February 26th, 2014, 07:05 PM   #73
Wramblerguy
Wramblerguy's Avatar
Default 4.5 stroker
Like stated before jus take your motor apart and see what is wrong with it before you assume it needs a complete rebuild
It could just need a rebuilt head like stated then you can rebuild your head, have head work done and maybe even a cam and be done with it
You wouldn't even need to pull the motor
3rd generation jeeper
Old February 26th, 2014, 07:09 PM   #74
SS
Bananarama!
SS's Avatar
He's not going to do anything mentioned here in this thread.
-Jer
Old February 26th, 2014, 07:24 PM   #75
You should look for a ford 5.0.
Old February 26th, 2014, 08:47 PM   #77
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Haha
H.o.r.e
Old February 26th, 2014, 09:49 PM   #78
2fst4you
2fst4you's Avatar
Will do. For the ones that have helped thanks a lot to the rest of you
Old February 27th, 2014, 07:02 AM   #79
I seen a used Coyote motor go for under $200, I would look into ford 5.0's
Old February 27th, 2014, 07:11 AM   #80
cj65
cj65's Avatar
If all else fails I have a good running 225cid slant 6 form a 1963 dart!
Page generated in 0.55761 seconds with 84 queries
