4.5 stroker - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2014, 08:10 AM   #41
wakeboard76
wakeboard76's Avatar
If you think your motor is ready for a rebuild, you should plan on new pistons, rings, and bearings regardless of weather or not you have to bore it out.
I do believe that a stock bore that is properly milled to get quench into spec will have low enough compression to run mid grade at least. Jeepstrokers.com has a compression ratio calculator you can use to figure this out.
wakeboard76 is online now   Reply With Quote
Old February 26th, 2014, 08:12 AM   #42
wakeboard76
I was under the impression that you thought you could build a stroker for $300 on top of the cost of just rebuilding the 4.0
Old February 26th, 2014, 08:22 AM   #43
lgottler
lgottler's Avatar
Originally Posted by wakeboard76 View Post
i was under the impression that you thought you could build a stroker for $300 on top of the cost of just rebuilding the 4.0
x2
lgottler is offline   Reply With Quote
Old February 26th, 2014, 08:48 AM   #44
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
X3
Old February 26th, 2014, 08:59 AM   #45
SS
Bananarama!
SS's Avatar
Wait... $300 total to rebuild a 4.0L AND stroke it?
-Jer
Old February 26th, 2014, 09:00 AM   #46
bigbchevy
missmrgreenagain
bigbchevy's Avatar
x4
H.o.r.e
Old February 26th, 2014, 09:30 AM   #47
wakeboard76
Last rebuild I did was 800 ish and we reused pistons...so, no.
Old February 26th, 2014, 09:39 AM   #48
buttercr125
I work out
buttercr125's Avatar
Originally Posted by hosejockey4506 View Post
i am currently collecting parts for a stroker, I was hoping this thread didnt get derailed so quickly haha
I am going to use a 258 crank and rods and get 6 over pistons and bore my current motor. I have heard with a mild stroker build you can compensate the computer programming aspect of it with mustange injectors and a adjustable fuel pressure regulator.
Its all french to me.
what machine shop are you using
I use a machine shop out in Holly that is called SGB Enterprises. The guy that owns it and does all the machine work there is a great guy. He does all the machine work for all of our shops. He has built several jeep stroker motors. One of them was in a Cherokee of I guy that I work with. It seemed to run well and held together through some abuse!! If you want his number shoot me a PM.
Old February 26th, 2014, 11:42 AM   #49
AFRd_CJ5
AFRd_CJ5's Avatar
Regardless if the $300 is the whole budget, or on top of the rebuild budget, I'd be tearing the thing apart first to see what I had to work with.
Spending $300 on parts to stroke it won't do a bit of good if you tear it down, realize you need to bore it (requiring pistons/etc.), then can't afford to finish it.
I still don't see the sense in worrying about 87 octane so much. You realize if you put 500 gallons of gas a year in it, if gas is $3.30 for 87 / $3.50 for 93, you'd only spend an extra $100 over the course of 500 gallons.
AFRd_CJ5 is offline   Reply With Quote
Old February 26th, 2014, 11:50 AM   #50
Please quite using logic.
Old February 26th, 2014, 11:56 AM   #51
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
And that's likely 5000-7500 miles a year, that's more than occasional use.
Old February 26th, 2014, 12:04 PM   #52
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Titan engines offers a complete stoker engine kit (including a machined block and rebuilt head) with all new parts for $2000. All you have to do is assemble it.
I'm the man in White.
Skooter_Built is online now   Reply With Quote
Old February 26th, 2014, 12:19 PM   #53
2fst4you
2fst4you's Avatar
Originally Posted by 8PTBUCK View Post
You do what you want buddy. You might as well wipe your ass with that $300 cause it ain't gonna be worth spending. I may be cheap, but at least i know how to think
You know nothing Joe
Originally Posted by cj65 View Post
Just do a stock rebulid with a little more bumpstick and spend your cash on the head. The best bang for the buck is head work. Power comes from the head and intake. The more air / fuel you can move = more power. Or save the cash do a stock rebulid and regear your ride.
What would you suggest I do to the head?
Is $300 really what you have/want to spend, or is that just a number you threw out there?
It will be 300-400 dollars for a 258 crank and rods
Originally Posted by Wehan View Post
X1558833558658566
Spend that $300 on a cam and headwork. I run a comp cams extreme 4x4 in my I6 along with a good valve job and love it.
Better yet, cam, get head rebuilt and then gasket match all the intake/ exhaust ports yourself with a $35 grinder set.
Suggest a cam over 258 crank and rods?
I want to see the receipts for this $300 stroker build. I bet he spends $300 before he even gets the old engine out.
I'm saying $300 for the crank and rods I know the whole rebuild will be more
Originally Posted by littletrucker View Post
If you don't feel the need to replace any internal bearings and your motor only has 115k on it why are you rebuilding it at all? Run it till it blows.
I hate it blowing smoke
Old February 26th, 2014, 12:24 PM   #54
2fst4you
2fst4you's Avatar
Originally Posted by lgottler View Post
If you have to rebuild your engine, why all the hate against trying to bump the HP a bit?
Picking up someone elses 4.0L seems like a gamble to me, you don't know its history. Stuffing another engine in it seems like a headache, your still left with someone elses engine plus everything behind it might not be up to it.
I have plans to stroke my 4.0L in the future as well, refresh it and get a little more out of it. I hope thread gets back on track....
Thank you!
I know I need new bearings, oil pump, water pump, rings, gaskets etc. I didn't think id need pistons for sure
No just for the crank and rods out of a 4.2
I will pm you thanks!
Just getting a plan I will be tearing it out once its warm
That's more than I want to spend but I appreciate it
Old February 26th, 2014, 12:28 PM   #55
kickstand
circling the drain
kickstand's Avatar
Originally Posted by 2fst4you View Post
Ya I'm not looking to spend that much. New can bearings even when my motor only has 115k on it?
For $300 more id be ok with 20hp
I may go to a 5.3 eventually but while rebuilding it why not spend $300 or so more to get a little more pep. It will be cheap and simple I'm not as cheap as you
I need to rebuild it just thinking about making a lil more power while in there
Good to know. Thanks
Will my quench and CR be fine with just putting in a 258 crank and rods I don't want to do pistons unless I have to. If I do this will I need special head gaskets?
Thank you!
At first I thought I would individually respond to some of the things you said. But instead I think this will cover it.
You need help, like skooterbuilt levels of help. Stop posting.
hahahahahaha
Old February 26th, 2014, 12:46 PM   #56
Skooter_Built
hahahahahaha
He's beyond my level, I know what's he's trying to do will fail spectacularly.
Old February 26th, 2014, 01:10 PM   #57
Wramblerguy
Wramblerguy's Avatar
Why would you spend 3-400 on a 258 crank and rods when I see whole motors go for 200 or less all the time
3rd generation jeeper
Old February 26th, 2014, 02:01 PM   #58
kickstand
circling the drain
kickstand's Avatar
Nobody surpasses your levels of stupidity, hording, ADD, and attention whoring. No one.
Old February 26th, 2014, 02:02 PM   #59
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old February 26th, 2014, 02:09 PM   #60
lgottler
lgottler's Avatar
Used that need to be pulled, then scrap rest, hope they are in good shape, send out to grind..... vs. In a box new? Is this the price difference?
Page generated in 0.57916 seconds with 83 queries
