4.5 stroker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2014, 10:52 AM   #1
2fst4you
2fst4you's Avatar
Default 4.5 stroker
Finally have the money to rebuild my 4.0 and well I'm in there I want to add a few more ponies. Looking at getting a 258 crank and rods. Do I need to get new pistons to keep the quench height favorable? Do I need anything else? Is getting .020-.030 bored over pistons worth it?
I want to maintain 87-89 octane
Thanks for the help!
Old February 25th, 2014, 11:11 AM   #2
masterbeatty
masterbeatty's Avatar
I don't know for certain but it seems like people keep the stock pistons. But I don't know for sure. I was wondering the same thing
Old February 25th, 2014, 11:20 AM   #3
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Wait when did you get monies
Old February 25th, 2014, 11:25 AM   #4
montecarlo33
The Violator
montecarlo33's Avatar
#inbeforethethreadgoesnowhereliketherest
Old February 25th, 2014, 11:26 AM   #5
I want to make power but I don't want to spend 6% more on fuel
Old February 25th, 2014, 11:28 AM   #6
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i am currently collecting parts for a stroker, I was hoping this thread didnt get derailed so quickly haha
I am going to use a 258 crank and rods and get 6 over pistons and bore my current motor. I have heard with a mild stroker build you can compensate the computer programming aspect of it with mustange injectors and a adjustable fuel pressure regulator.
Its all french to me.
what machine shop are you using
Old February 25th, 2014, 11:35 AM   #7
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Will this be done before Silver Lake?
Old February 25th, 2014, 11:38 AM   #8
hoyt5885
hoyt5885's Avatar
I just did this I used a 258 crank and rods with speed pro 4.0 pistons bored 30 over I used a mild crane cam. And mustang 24lb injectors I am still using pump gas. But I have around 1500 in the motor that is all parts and machine work on the block, crank , and head
hoyt5885 is offline   Reply With Quote
Old February 25th, 2014, 11:45 AM   #9
2fst4you
2fst4you's Avatar
Taxes and I'm going to start working with my uncle
I already put premium in my car don't want to have to put it in my jeep and its more money to build a stroker requiring 93. I just want a mild stroker
That sounds correct. Not sure yet about to start collecting parts
Yes
What octane are you running? How much was the cam?
Old February 25th, 2014, 11:56 AM   #10
Gunsworth
Gunsworth's Avatar
Lolz pretty much...
Old February 25th, 2014, 12:00 PM   #11
How?
Old February 25th, 2014, 12:25 PM   #12
joe_jeep
welfare wheeler
joe_jeep's Avatar
If you dont have to bore the block and can use stock pistons it can b fairly cheap and run on 87 oct fuel.
some 4.0l heads do hot spot in the combustion chamber. Often polishing the head in the top of the combustion chamber around the valves can help. Get it nice and smooth, with out removing too much material. Piston quench height needs to be set correctly for it to run well. Thicker and thinner head gaskets are avialable. U can also shve the head or deck the block if necessary.
Old February 25th, 2014, 12:31 PM   #13
silveradoboy
Sam Brown
silveradoboy's Avatar
silveradoboy is offline   Reply With Quote
Old February 25th, 2014, 12:43 PM   #14
Get a louder exhaust and you will feel faster.
Old February 25th, 2014, 12:50 PM   #15
AFRd_CJ5
AFRd_CJ5's Avatar
How?
x2
How is it more money to build one that requires 93?
How much will you drive this?
AFRd_CJ5 is offline   Reply With Quote
Old February 25th, 2014, 01:03 PM   #16
2fst4you
2fst4you's Avatar
How?
Maybe I'm wrong just figured boring it more and running bigger pistons would cost more
The plan is keeping the stock pistons if possible if not I guess I'll bore .020-.030 over
Wish that helped lol
Originally Posted by AFRd_CJ5 View Post
x2
See above. A few days during the summer besides that its for wheeling only
Old February 25th, 2014, 01:22 PM   #17
AFRd_CJ5
AFRd_CJ5's Avatar
Pistons aren't the only factor in octane requirements. Cam choice also plays a large part in this (if you're considering a cam swap).
If you have to bore the cylinders, you have to get new pistons anyway. Unless you're buying some custom units, I don't see where something with a little more compression is going to add much (if any) to your build. Add the fact that worse case scenario, you have to deck the block or mill the heads to achieve a flat surface... You may end up with more than you want anyhow.
If you're only going to use this for what you're saying, I can't see how it's worth putting a lot of time/effort into something so you can run fuel that's $.10 cheaper a gallon?
Old February 25th, 2014, 03:09 PM   #18
2fst4you
2fst4you's Avatar
I don't plan on changing the cam. I want to do 258 crank and rods and stock 4.0 pistons. If I do bore over it will be .020-.030 and id like to avoid high CR so I can run 87. If that's not possible ill live with running higher octane
Old February 25th, 2014, 03:15 PM   #19
kickstand
circling the drain
kickstand's Avatar
I want to know if you fell out of the same tree as skooterbuilt.
Old February 25th, 2014, 03:20 PM   #20
hoyt5885
hoyt5885's Avatar
i have 200 in a cam and lifters and i am running 93 right now have not tried running 87-89 yet. i have 200 in boring the block, instaling new cam bearings and hot tanking the block. 150 in the head which incudes valve job and decking the head to insure it was straight. 200 in the cank that was turning it to .10 to .10 on main and rod journals and makeing sure it was straight. 80 in injectors from ebay 200 for pistons,rings,and cam bearings. 100 in main and rod bearings and 90 in a oil pump. if u are gonna do a rebuild i would most defintly put new cam bearings in it. if i wereto do it all over again i would save the moiney fro the stroker and just go 5.3 in it. or find a good running 4.0
Page generated in 0.37233 seconds with 83 queries
