So, I was at the gas station today, and this is what I noticed. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2014, 09:32 PM   #1
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Default So, I was at the gas station today, and this is what I noticed.
The pump offers 87, 89, and 93 octane fuel. However, I think that one is labeled as the other.
So, is paying for 89 octane useless, as the 87 is really 89, or is the 89 really 93?
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old February 12th, 2014, 09:50 PM   #2
Muttly
Muttly's Avatar
or maybe 87 and 93 are blended to get 89?????????
Muttly is offline   Reply With Quote
Old February 12th, 2014, 09:50 PM   #3
dreezy
Haggard Fab
dreezy's Avatar
The only difference between 87 and 89 are the additives and costs the same to produce.
Old February 12th, 2014, 10:06 PM   #4
joel216
joel216's Avatar
I am pretty sure 87 and 93 are blended to make 89.
joel216 is offline   Reply With Quote
Old February 12th, 2014, 10:09 PM   #5
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
^^ When we got our 95 Octane drop at work its 97 and 93 mixed..
Spence1986 is offline   Reply With Quote
Old February 12th, 2014, 10:47 PM   #6
brock430
HOLY CRAP!
brock430's Avatar
I dont thing 87 and 93 make 89. The gas station by my house always runs out of 87 (poor management) but they still offer 93 and 89. Well it could be blended somewhere else but not at the pump.
brock430 is offline   Reply With Quote
Old February 12th, 2014, 11:25 PM   #7
oz97tj
Wasn't this attached?
oz97tj's Avatar
Its blended at the pump. If the 87 tank is empty you are getting 93 for the price of 89.
********GLFWDA.org********
Old February 13th, 2014, 05:48 AM   #8
jaysusr
jaysusr's Avatar
Kinda like offroad diesel and on road diesel? I figured it came out of the same tank, but had dye mixed in by the pump....
Old February 13th, 2014, 09:08 AM   #9
clarkstoncracker
lol
clarkstoncracker's Avatar
That is a gilbarco blender pump.
Sunoco and Mobile stations use blender pumps. They usually have two regular tanks, and one premium. It's cheaper to install and maintain, but the down side is, if one of the big flow pumps in tank fails, it will either knock out reg, and midgrade, or midgrade and premium. When shell, speedway, or marathon stations have a pump failure, it knocks out only one grade of fuel.
Old February 13th, 2014, 09:19 AM   #10
clarkstoncracker
lol
No. That is not how it works. In michigan, every station is required to have an intrinsically safe tank monitoring unit. Most of them say VEEDER ROOT on the front, and you can see them from the POS. If a tank is below 8%, they will lock out the pump from running. Those underground tanks have a huge amount of garbage and water in the tanks, and the veeder root monitors have three floats. One for sludge, one for water, and one for fuel. (this is why you should NEVER fill up when a tanker is dropping fuel, it mixes all that shit up in the tank) The relay cut off occurs if the water / fuel sensor are within 8%, or if the tank is freshly flushed, and there is no water, the cut off appears at 8% between fuel level and the tank being empty.
Those big flow pumps are around 20k, and roughly 40 man hours to swap out. They do not let those pumps run dry.
Also, gilbarco blenders have pressure switches. If one of the two feeds is not proper, the pump will stop dispensing. The pumps also have the ability to blend a 30% pressure difference, so if a premium pump is putting out 55psi, and 7 people are pumping premium, the line pressure might be 40psi, the pump can still do a perfect blend between the 40psi premium and the 55psi regular to make the proper 89 blend.
All pumps must also be flow tested and octane tested once a year, you can see the seals on the pumps. The state also does random octane testing.
Anyway, that is how blender pumps work.
source: I'm veeder root certified.
Old February 13th, 2014, 09:26 AM   #11
Also, gilbarco blenders have pressure switches. If one of the two feeds is not proper, the pump will stop dispensing. The pumps also have the ability to blend a 30% pressure difference, so if a premium pump is putting out 55psi, and 7 people are pumping premium, the pressure might be 40psi, the pump can still do a perfect blend between the 40psi premium and the 55psi regular to make the proper 89 blend.
Old February 13th, 2014, 10:07 AM   #12
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
Pfft, you just made that shit up.
TJJEEP is offline   Reply With Quote
Old February 13th, 2014, 10:20 AM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
This is what I envision at the refinery..
JohnnyJ is online now   Reply With Quote
Old February 14th, 2014, 08:52 AM   #14
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Old February 14th, 2014, 08:59 AM   #15
mmmmmmmmmmmmmmm
Old February 14th, 2014, 09:03 AM   #16
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
mmmmmmmmmmmmmmm
I like Guiness, too. It's my diet beer. ;)
Old February 14th, 2014, 09:28 AM   #17
I vote this is what we start calling you.
Old February 14th, 2014, 09:38 AM   #18
kickstand
circling the drain
kickstand's Avatar
I support this notion.
Old February 14th, 2014, 10:54 AM   #19
wilesin
10ptbuck
wilesin's Avatar
Aye
wilesin is offline   Reply With Quote
Old March 28th, 2014, 08:20 PM   #20
chevotass
chevotass's Avatar
I changed a VEEDER ROOT guage today. the operator couldn't figure out why I was laughing. And without your fancy certification. put that in your pipe and smoke it.
(new gauge was already certified)
Page generated in 0.52100 seconds with 83 queries
