air tank - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2014, 07:36 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default air tank
I used this for bagging fish, if you add a attachment at the end of the hose this would be great for you serious off road guys. It would give you a air tank that doesn't need to be run by a motor.
Tank is stamped good til 2015, the regulator is missing one glass lens but still work.
Filled with air
$100 obo
mideerslayer is offline   Reply With Quote
Old February 10th, 2014, 08:02 PM   #2
michigan maniac
michigan maniac's Avatar
What's the regulator max psi ?
Old February 10th, 2014, 08:16 PM   #3
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Why would we want to fill our tires with Oxygen?
Old February 10th, 2014, 08:36 PM   #4
mideerslayer
NEVER GIVE UP!
don't you fill your tires with air?
Old February 10th, 2014, 08:41 PM   #5
mideerslayer
NEVER GIVE UP!
4000 psi
Old February 10th, 2014, 08:57 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea air, or CO2. Not oxygen. Isn't that an oxygen tank? Looks like one.
Old February 10th, 2014, 09:40 PM   #7
af26yrs
af26yrs's Avatar
Oxygen tanks are bright green so I do not think it is oxygen. Even if it was doesn't mean you have to fill it with oxygen.
af26yrs is offline   Reply With Quote
Old February 10th, 2014, 10:12 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
If it's a O2 tank then the filling place won't fill it with anything else. Not all are bright green, some are a darker green like this one looks like because it is industrial and not medical and the regulator says oxygen on it. My torch setup out in the garage has dark a dark green tank. If you were going to fill it yourself with your compressor, it wouldn't hold very much volume of compressed air at 120 psi. Maybe 1 tire. I can't tell if it's an R or an RR tank which is only 20-40 CF at 2200 psi.
Old February 10th, 2014, 11:03 PM   #9
mideerslayer
NEVER GIVE UP!
it is a o2 tank. I used it to bag fish. It has other uses I just threw a idea out there.
I wont be using it so I am selling it :)
Old February 17th, 2014, 04:44 AM   #10
mideerslayer
NEVER GIVE UP!
$60
I am tripping over it
Old February 17th, 2014, 12:29 PM   #11
swampjeep
Swamp Stomper
swampjeep's Avatar
most places around here will trade like size tanks, you can walk in with a 20lb O2 and walk out with a full CO2 tank for just the cost of the gas
swampjeep is offline   Reply With Quote
Page generated in 0.25129 seconds with 56 queries
