How to identify a axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2014, 08:25 PM   #1
cj65
cj65's Avatar
Default How to identify a axle
So I need to know what axle is in my 1996 suburban 2500. I know its a 14 bolt but I need to know if it is ff or semi float how do I tell the difference? And then I need to know if it has a 9.5" ring gear or a 10.5" is t here anyway to tell without taking the axle cover off?
Old February 8th, 2014, 09:11 PM   #2
koochman450r
koochman450r's Avatar
Yes. Tell me where to meet you and I'll tell you. First pic is full floater. Second is semi float.
you won this battle.
Old February 8th, 2014, 09:16 PM   #3
Gunsworth
Gunsworth's Avatar
Originally Posted by koochman450r View Post
Off topic but isnt antisieze a nono on studs?
Also goo to knownhow to identifiy them, never knew that. Guess I got a ff on my 2500
Old February 8th, 2014, 09:30 PM   #4
firehawk
Live Action!
firehawk's Avatar
I have used antisieze on studs but also agree that I have heard it should not be used there.
I would use it again but don't usually.
Old February 8th, 2014, 09:40 PM   #5
PinItToWinIt
PinItToWinIt's Avatar
Very little antisieze goes a long way.. With that said I use it on lug nuts but keep it light.
PinItToWinIt is offline   Reply With Quote
Old February 8th, 2014, 09:42 PM   #6
Toyfish
Toyfish's Avatar
Antiseize is a big nono on lugs i have used it hub faces to keep wheels from being stuck on
Sent from my DROID X2 using Tapatalk 2
Old February 8th, 2014, 09:46 PM   #7
koochman450r
Antisieze or any type of lubricant is recommended on studs. Always!! Light oil or grease. Lubrication on the threads increases clamping force up to 10% if not more. This is coming from Arvin meritor, Rockwell, Eaton, Alcoa, Michelin, good year, and many heavy truck manufacturers.
Old February 8th, 2014, 09:49 PM   #8
MARTIN HASSENGER
BRONCATRON
MARTIN HASSENGER's Avatar
I believe all FF 14bolts are 10.5 ring gear. Could be wrong thou
MARTIN HASSENGER is offline   Reply With Quote
Old February 9th, 2014, 06:40 AM   #9
cj65
cj65's Avatar
Thank you mine is a ff looks like the first pic. All I need to do is figure out if its a 10.5 " ring gear. Asking for a disc brake conversion.
Old February 9th, 2014, 07:34 AM   #10
Tab
Tab's Avatar
If it's the full floater it's 10.5".
Old February 9th, 2014, 04:22 PM   #11
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
this
Old February 9th, 2014, 06:21 PM   #12
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Easiest way to tell without pulling a hub cap is that the 10.5" full-float 14-Bolt has a removeable pinion support. It will have 6 bolts around the yoke area (front) of the differential. The semi-float 9.5" 14-Bolt doesn't have this.
Page generated in 0.37342 seconds with 59 queries
