Charge controllers and Battery types - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > The Great Outdoors
The Great Outdoors Guns, Cannons, Fishing, Camping, and other fun stuff
Old February 5th, 2014, 10:14 AM   #1
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Default Charge controllers and Battery types
Last fall my uncle and I set up a solar power/battery bank system at the family camp. The set up is a 140 watt panel ( i believe 140, could be a bit more), 2 group 31 batteries, and a 30 amp MPPT charge controller.
This spring/summer we are going to be adding a second panel and two batteries. I picked up 3 exide group 31 gel batteries that are going to be used. the other two are just sealed lead acid
My question is, can the charge controller be used with two different type batteries? One of the current batts is for my uncles boat so it will be the 3 gels and one SLA. I can't find anything online about using a charge controller with different types of batteries. The controller lets you change what battery type, but is it ok to use it with 2 different types? I know that chemically they are basically the same. Just wanted to ask someone who knows more than me
Old February 7th, 2014, 10:05 AM   #2
wave_crusher
I'll Direc your TV
No one has experience with solar systems????
Old March 4th, 2014, 08:28 PM   #3
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
a friend of mine has been ''off the grid'' for 12 or so years now and has a pretty nice 2kw home solar panel set up, I ll ask him tomorrow about it-Dave
broncobuddha is offline   Reply With Quote
Old March 5th, 2014, 05:03 PM   #4
broncobuddha
Starting over
from my buddy, DONT mix battery types, you will have a "weakest link" in that the batteries need to be closely matched to charge and discharge safely and efficiently, same to a lesser extent for the panels too, he says your best bet would be to ad a 4th gel battery and another 140w panel
Old March 7th, 2014, 08:57 AM   #5
wave_crusher
I'll Direc your TV
Thanks, I appreciate the help
We were going to be adding another panel anyway, so i'l pick up another gel battery
Old March 7th, 2014, 07:28 PM   #6
broncobuddha
Starting over
no problem, I want a similar setup for power outages at home, 2 240 w panels with 4 t 105 Trojans will run the lights and tv and laptop for a long time
Page generated in 0.28362 seconds with 41 queries
