2002 2500 growl in 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2014, 11:02 PM   #1
Jiveturkey3
Jiveturkey3's Avatar
Default 2002 2500 growl in 4wd
So I am in the process of trading my 2002 dodge 2500 5.9 CTD. I switched with the guy as I know him very well. He calls me and said in 4wd it growls pretty loud at speed. I haven't used 4wd much other than going in and out of the woods.
I replaced the front axle seals and ad the shafts out.
Can the cad collar be and issue? 4wd works fine. No noise in 2wd. Could that double u joint make a growling noise of going bad? I am aware it could be a bearing but it was fine last winter and hasn't been drove more than 600 miles in a year. I'm not sure where to start. He seems to think its the t case.
Jiveturkey3 is offline   Reply With Quote
Old February 3rd, 2014, 08:28 AM   #2
kickstand
circling the drain
kickstand's Avatar
cv joint on driveshaft
Old February 3rd, 2014, 09:52 AM   #3
montecarlo33
The Violator
montecarlo33's Avatar
Also check u joints on front shaft.
Old February 4th, 2014, 12:03 PM   #4
Jiveturkey3
Yup cv joint is trashed. Easy fix. Thanks guys.
Old February 4th, 2014, 12:07 PM   #5
kickstand
circling the drain
kickstand's Avatar
Old February 6th, 2014, 02:22 AM   #6
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
No CAD on the 02, cv joint for sure.
BigWheelBob is offline   Reply With Quote
Page generated in 0.22457 seconds with 41 queries
