Pondering axle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 1st, 2014, 07:02 PM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default Pondering axle swap
98 xj
currently has a 8.8, disk braked, 4:88, spool, hd cover
dana 30, 4:88 lunch box, heavy cover, upgraded steering ect
think is worth the 44 and 9 in swap? i have the 79 hp 44 with correct drop and matching 9in but, i will be starting all over with gears,lockers, mounts,ect.
looking for constructive responces
Old February 1st, 2014, 07:04 PM   #2
Grassman
2jz specialist
Grassman's Avatar
id leave it
Old February 1st, 2014, 07:11 PM   #3
mudrunner456
mudrunner456's Avatar
Yes i would definetly just leave what you have in there alone. If you didnt already have gears lockers and what not then go for it. But the money you will spend on the new axle wont be worth the little you will gain in strength.
mudrunner456 is offline   Reply With Quote
Old February 1st, 2014, 07:12 PM   #4
caleb24v
RUMPELEDSTEELSKIN
I wouldn't swap either.
caleb24v is offline   Reply With Quote
Old February 1st, 2014, 07:15 PM   #5
ljense8
Web Wheeler
ljense8's Avatar
Maybe get the 44/9 in combo geared and locked how you want them, then wheel the old axles until something breaks. That way you have some nice backups that can just be swapped in easily.
ljense8 is offline   Reply With Quote
Old February 1st, 2014, 07:21 PM   #6
Little Dave
Little Dave's Avatar
Originally Posted by unclebeaner View Post
98 xj
When was the last time you broke something on them? If your not breaking what you have now don't change. If you do swap find a 60 and loose the 44.
Little Dave is offline   Reply With Quote
Old February 1st, 2014, 07:31 PM   #7
cerial
Direct Drive FTW
cerial's Avatar
Keep the tire size under 35", sell the 44/9", upgrade your shafts, shove in some 44 joints, and truss the 30 if you have not done so already.
Old February 1st, 2014, 09:35 PM   #8
unclebeaner
thanks for talking sense into me, it will occasionally break a front shaft but not very often. i run a 35in tire. ill leave it alone i suppose. or see if i can find a deal on a 60 lol
Old February 1st, 2014, 09:42 PM   #9
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
I think you should sell you current axles, and I know the right person to buy them...lol
mudviper is offline   Reply With Quote
Old February 1st, 2014, 09:48 PM   #10
unclebeaner
its not out at all looking at my options right now, going to look at a 60 tommorow, if my plan would of worked i would have a 60 and a fab 9 but people cannot hold to their word on selling things.
Old February 2nd, 2014, 07:26 AM   #11
Wrong approach. The question is what is your long term goal for tire size and type of wheeling? What about the 44/9 interests you? What about the 30 don't you like? The joint size of your 30 and a 44 are the same. If you are not going above a 35" tire, going to a 60 is not worth the time, money and you will have a heavy low dragger. How much money do you want to drop into it?
Monkeyevil posted this a long time ago about cost comparisons.
60 vs 44 costs (cause this is so much fun!) - Great Lakes 4x4. The largest offroad forum in the Midwest
Personally, if you decide to go with a 60, I would still build the 9". The 9" has about as much versatility as you can want, I've been very happy with my setup.
Old February 2nd, 2014, 08:00 AM   #12
cj65
cj65's Avatar
If you are going to swap for sure keep the 9" nothing stronger than this when you take in the weight compared to a 14 bolt or 60. A 9" has 3 pinion teeth that are in contact with the ring gear. Most all others only have 2. And on top of that the aftermarket world for a 9" well you know whats out there. We just bulit a 9" with 44 knuckles for my friends jeep. Now he has a 9/9 combo great strength and less weight than a 44 or 60.
Old February 2nd, 2014, 09:42 AM   #13
unclebeaner
9in will stay no matter what, if my 1000hp+ drag car couldnt break it the sure wont. Plus i have a nice aluminum mark williams center section ill be using left over from car.
Old February 2nd, 2014, 07:35 PM   #14
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Wise choice! 44's are a waste of money!
Page generated in 0.31146 seconds with 66 queries
