K5 Toyota Prerunner - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2014, 01:33 PM   #1
K5 Yota
Default K5 Toyota Prerunner
I started with a 1987 Blazer then striped it down to the frame. I got a different motor and transmission for it, turbo 350 2wd, chevy 350. I went through the motor refreshing the top end with a pro comp cam package and rocker arms. Edelbrock intake and Holley carb. I got a 14 bolt 6 lug sf rear axle from my friendly local junkyard. 1992 Toyota pickup cab is going to be on the K5 frame. The body is from the south with no rust. I'm making a custom front axle. I cut the old K5 front axle at the knuckles and I have a tube to fill the difference. At the same junkyard I got a power steering box off a 2wd older chevy pickup. That will allow me to have crossover steering. I also have some 6 inch lift Rubicon Express coils for the front. Now i have been working on making the frame stronger by boxing it in and making new crossovers.[url=http://www.greatlakes4x4.com/vbimghost.php?do=displayimg&imgid=34151]
ID:	113926   Click image for larger version
ID:	113927   Click image for larger version
K5 Yota is offline   Reply With Quote
Old February 22nd, 2014, 08:32 PM   #2
K5 Yota
Default Frame work
Here is some pictures on my plating process and gas tank mounting.
Old February 22nd, 2014, 08:35 PM   #3
RossDickman
RossDickman's Avatar
Looks good Chad! Keep the work up and post more pics
RossDickman is offline   Reply With Quote
Old February 22nd, 2014, 11:16 PM   #4
t_ank
t_ank's Avatar
More pictures gonna be sweet build
t_ank is offline   Reply With Quote
Old March 1st, 2014, 11:12 PM   #5
K5 Yota
Here is my front axle, coil springs, and leaf springs
This is kinda what it might look like when done
Old March 1st, 2014, 11:25 PM   #6
vteckickin
I like this build keep the pics comeing
vteckickin is offline   Reply With Quote
Old March 23rd, 2014, 04:33 PM   #7
K5 Yota
Ordered all my builder parts from Ruff Stuff and Rusty's Offroad
Jeep drop pitman arm
Rear axle cleaned up a little bit
Old March 23rd, 2014, 06:13 PM   #8
t_ank
t_ank's Avatar
gonna be awesome
Old March 23rd, 2014, 07:26 PM   #9
K5 Yota
I want to give a special thanks to friends, family, and all the positive input from the Great Lakes 4x4 crew
Old March 23rd, 2014, 09:10 PM   #10
Wramblerguy
Wramblerguy's Avatar
Very interesting
Me likey
3rd generation jeeper
Old March 24th, 2014, 06:18 PM   #11
RossDickman
Got some good stuff done this weekend eh? Did you end up drilling that pitman arm?
Looks good bud
Old March 24th, 2014, 08:02 PM   #12
K5 Yota
I'm going to bring the pitman arm to Mitch's work to drill out and make some coil buckets
Old March 30th, 2014, 10:18 PM   #13
K5 Yota
I got some parts form the junkyard 50% off sale
Made some coil buckets, retainers, and drilled out my pitman arm just a bit
The top buckets are a little bulky but they will work great
Old March 30th, 2014, 10:43 PM   #14
86scottsdalek10
86scottsdalek10's Avatar
Cool start, anything prerunner catches my eye. Can't wait to see it progress more
86scottsdalek10 is offline   Reply With Quote
Old March 30th, 2014, 11:57 PM   #15
koochman450r
koochman450r's Avatar
Is that the factory k5 steering box?
you won this battle.
Old March 31st, 2014, 08:49 AM   #16
K5 Yota
The steering box is off a 2wd 80s chevy pickup
Old March 31st, 2014, 06:21 PM   #17
koochman450r
Ok, just making sure you swapped it out for it to work properly. Looks good man
Old March 31st, 2014, 09:35 PM   #18
K5 Yota
Thanks for the concern
Old March 31st, 2014, 11:04 PM   #19
RossDickman
You order that tube yet ya slacker?
Old April 3rd, 2014, 03:08 PM   #20
K5 Yota
Yep, and its going to cost a pretty penny
Page generated in 0.60869 seconds with 84 queries
