Lockers and ABS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2014, 05:04 PM   #1
BlooMule
Old School
BlooMule's Avatar
Default Lockers and ABS
After driving in the slop we've had lately, and feeling the ABS kick in a time or two- I got to wondering.....
If you have a locker in either axle (or both) does it mess up the anti-lock brakes? Seems to me if you are in 4WD and have a locker, that newer ABS that controls wheels independently may not like it. I don't know much beyond the basic idea of how ABS functions, so maybe those that know can answer...
-rw-rw-rw
Old January 27th, 2014, 05:55 PM   #2
cerial
Direct Drive FTW
cerial's Avatar
Generally ABS works on the principle that if one wheel is moving faster then the other during breaking it must be slipping and it applies ABS to that corner until all wheels are moving at the same speed.
Some rear axles only have one rear sensor and the ABS pulsates both rear breaks during breaking.
So, if you were taking a turn with lets just say a spool. Then brake'd with one of the wheels moving faster the ABS would kick in. If you had a single sensor rear axle it would pulsate both rear breaks and could cause a slide. With 4 speed sensors at the hubs it would pulsate the single wheel moving faster breaking it. You would have a shaft vs rotor situation which could cause increased break wear.
Old January 29th, 2014, 09:53 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Actually, if a wheel is moving faster than the other during braking then the other wheel is locked up, which would cause ABS to cycle that wheel, not the one that's moving faster.
If a wheel is moving faster than the other during acceleration, then it is slipping/spinning.
Old January 30th, 2014, 07:57 PM   #4
Muttly
Muttly's Avatar
If you have a spool how would one of the wheels turn faster than the other?
Muttly is offline   Reply With Quote
Old January 30th, 2014, 08:56 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
When you break something!
Page generated in 0.25519 seconds with 38 queries
