long arm setup - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2014, 05:18 PM   #1
bighroder
bighroder's Avatar
Default long arm setup
I asked this on pirate4x4 didn't get much of any info I'm gunna start collecting parts. Would like to know which setup would be the best for me. Truck is 96 2500 dodge ctd which willbe getting a 4bt. Truck will see dd duty with weekend wheeling have a kingpin d60 going up front.....
Alright so ive been researching. Optimally I would like 3-5" of lift max I've been looking at different types of long arms such as dor's kit with bent upper links
Or another kit I've found pictures of with shorter upper arms
My only questions are seems as I would like to build my 4 links the second of the 2 would be easier to make what does the different arms do to geometry when it goes droop to stuff?
I would assume it changes pinion angle more then equal arms?
What is the best, most reliable rod end/ bushing to go with for street and offroad use?
bighroder is offline   Reply With Quote
Old March 15th, 2014, 07:25 PM   #2
Brand97
Curious to hear what you have found I am doing the same collecting pieces... Thanks
Brand97 is offline   Reply With Quote
Old March 22nd, 2014, 01:03 PM   #3
TheDodgeGuy
PR MTU 4X4
TheDodgeGuy's Avatar
DOR sells bent or straight long arms, depends on your lift and tire setup. The bent arms are only bent so your tires dont rub and you can run them on shorter lifts. IIRC overall length from end to end is the same, but I would go with the DOR arms. They make their parts really beefy, and they are made to last.
TheDodgeGuy is offline   Reply With Quote
Page generated in 0.22865 seconds with 32 queries
