grooving a super swamper is it worth it?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2014, 04:58 PM   #1
mudrunner456
mudrunner456's Avatar
Default grooving a super swamper is it worth it??
Just picked up a set of 36" super swamper tsl's with over 90 percent tread. I am thinking about grooving them. My last set of tires were the same ones and i grooved them but they were so low on tread to begin with i couldnt really tell a difference. I wheel in the snow alittle. But mainly mud and the dunes. Wondering if you guys have expieience with grooving bramd new tires and if its really gaining you anything.
mudrunner456 is offline   Reply With Quote
Old January 26th, 2014, 05:31 PM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I've owned two sets of 36" tsl bias, one low on tread and one set great tread. Both did much much better after I grooved them especially in snow and on rocks.
Old January 26th, 2014, 05:36 PM   #3
Tab
Tab's Avatar
Yes. I loved the triangles.
Old January 26th, 2014, 05:50 PM   #4
mudrunner456
Any big issues with the lugs tearing off. I dont spend much time in the rocks.
Old January 26th, 2014, 05:53 PM   #5
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Don't groove the outer lugs...
The Kernel (46 CJ2a)
Wow, i would lick those...
Old January 26th, 2014, 06:00 PM   #6
Tab
Tab's Avatar
I cut the inners into triangles and just put a groove down the middle of the outer lugs except the small ones. Never ripped one off but the outers do wear fast on the rocks and pull off little pieces.
Old January 26th, 2014, 06:09 PM   #7
mudrunner456
Well i would be doing it mostly for more traction in mud and snow. Not a fan of the rocks. The jeep doesnt see much for road use but id have to guess this would excel tire wear if driven alot in road.
Old January 27th, 2014, 01:05 PM   #8
This is how I always did mine, they work great in the snow and on rocks. Mud, I don't think it makes much difference, but it won't hurt it for sure. Sand, never had them in sand :dunno:
Old January 27th, 2014, 01:26 PM   #9
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
X3. I did the same thing with my 42's. Worked great everywhere.
Old January 27th, 2014, 01:29 PM   #10
xj4life
xj4life's Avatar
grooved some good tread TSL's back in the day and they did a lot better in all conditions
something like this
Old January 27th, 2014, 01:33 PM   #11
mudrunner456
Thats the exact pattern i was thinkin. Gonna get started on them tonight
Old February 11th, 2014, 05:52 PM   #12
lgottler
lgottler's Avatar
Anyone have experience with more of a cutting instead of a groove? I'm thinking of going this route as well as adding siping on the center blocks, very narrow slits. Whenever my groover arrives in the mail...
lgottler is offline   Reply With Quote
Old February 11th, 2014, 06:06 PM   #13
koochman450r
koochman450r's Avatar
I did this to my 36" spare. Wasn't too bad to do. Just used the wide blade on my groover and went to town. and used the narrow knife on the small outer lugs. Grooved the other four with just straight wide grooves on the middle and two larger outside lugs.
you won this battle.
Old February 12th, 2014, 07:36 PM   #14
michigan maniac
michigan maniac's Avatar
The last 2 pics look pretty sweet
Old February 12th, 2014, 07:52 PM   #15
mudrunner456
Yea those definetly look bad ass but i dont know if i could cut brand new tires that much
Old February 12th, 2014, 07:59 PM   #16
lgottler
lgottler's Avatar
Easy, I'll cut them for you! Lol
Old February 12th, 2014, 08:30 PM   #17
pipepro
Tack it
pipepro's Avatar
Seems like mine got a lot more bite in soft dirt after I grooved them.
pipepro is offline   Reply With Quote
Old February 12th, 2014, 08:36 PM   #18
mudrunner456
I still havnt done mine. Couldnt bring myself to do it yet. Gonna try them out at dog party this weekend. Eventually im sure ill do it but for now the regular pattern will be a ton better then the smoothies i was running before.
Old February 13th, 2014, 07:15 AM   #19
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
You'll cut them... Then you'll wheel it and go, they're awesome, then you'll cut them again, deeper... They definitely make a big difference.
Cheap Thrills Off Road
Old February 13th, 2014, 10:05 AM   #20
michigan maniac
Just cutting lines threw each tread block does help the tire fold better over objects to get more traction, if your scared to hack to much out just start with doing the main inside lugs
Page generated in 0.34994 seconds with 84 queries
