14 bolt six lug - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2014, 11:43 AM   #1
davidkassie
davidkassie's Avatar
Default 14 bolt six lug
what year 14 bolt six lug semi floating axle will fit into a 1999 suburban? any mods to the u-joint or shocks? etc.. any disc brake conversions from factory stuff? thanks !!
davidkassie is offline   Reply With Quote
Old January 26th, 2014, 04:40 PM   #2
davidkassie
No advice?
Old January 26th, 2014, 04:53 PM   #3
Ebs
If you want to bolt it in you want one from the same body style pickup. I remember 2wd and 4wd ones being different widths. You're basically looking for a 4wd half-ton w/ the high GVWR package, known as a 'heavy half-ton'. The six lug 3/4 tons mostly seemed to be 2wd.
I'm not sure about the u-joint, but conversion u-joints are readily available if it needs one.
That's all I remember from when I was searching one out years ago.
Old January 27th, 2014, 11:06 AM   #4
davidkassie
K, thanks...
Page generated in 0.17865 seconds with 35 queries
